Old 12-26-2004, 10:16 PM   #1
Send a message via Yahoo to phillip266
What v 12 or 24 who knows?
as i have sad before iam geting my bus with the next 6 weeks was woundering if anyone that has a diesel can tell me are the diesel systems 12 v or 24 v Resion i asked is all the big rigs and diesels i have run in have been 24v systems
if thire 12v systems it would be great but wanted to asked before geting things i dont need
Cool things happen when Great Minds come togather :)
phillip266 is offline   Reply With Quote
Old 12-30-2004, 07:37 AM   #2
lapeer20m's Avatar
It is most likely a 12 volt system. I have yet to run across a skoolie (as far as i know) that was 24 volts. I don' drive a truck for a living, but I run across quite a few fire trucks and other rescue equipment on big truck chassis, and they've all been 12 volt as well.
24 just isn't that common in north america......outside the military. The US govt. is one place i've seen a lot of 24 volt vehicles. Someone told me our military vehicles are set up the same as other vehicles in NATO or something like that...
If you look at the battery, it should tell you how many volts it is. If there is more than one battery, you would have to see if they were wired in paralell or series. Perhaps an easier method would be to remove a light bulb from anywhere in the bus and see what the voltage rating is. That should be clearly marked on the base of the bulb. You could always plug in a standard 12 volt light bulb to the bus and see what happens. If it keeps working for more than a nano-second, then the bus is a 12 volt system. A volt meter would also tell you the votage. Remember it won't be exactly 12 or 24 volts as these numbers are nominal. Perhaps the easiert method of all would be to ask the seller.
What kind of bus are you looking at?
Old 12-30-2004, 11:47 AM   #3
12v or 24v
well i know that all 18wheeler
rigs are 24v and thaty run diesel
motors thats why i asked if the
diesel school bus were 12 or 24v
as me and my dad have drove many
Big rigs and 24v is comman in them
