Old 07-19-2019, 01:15 PM   #1
What Would You Do?
So my genset harness has large connectors on each end. My dilemma is should I cut a big hole in the floor to accept the connector, or cut the wires and utilize a much smaller hole, splice wires back together.
Old 07-19-2019, 01:18 PM   #2
Cut a hole, pull wire and patch around it. Can you find a “gasket” that would work? Maybe a rubber plug used for plumbing?
Old 07-19-2019, 01:20 PM   #3
Or, can you get the connectors out of the plug? Are there little plastic tabs holding the connectors in that you can push with a needle and pull out, then reassemble?
Old 07-19-2019, 01:21 PM   #4
Chassis: B3800 Short bus
I would personally mark each wire (different coloured marker perhaps?) and the connector then pop the connector pins out. Usually you can slide a safety pin between the crimped connector on the wire to compress the detent and pull it out.
Old 07-19-2019, 01:22 PM   #5
They apparently make tools for the job.. When I need to do the task I grab whatever pointy metal thing I have lying around.
Old 07-19-2019, 01:25 PM   #6
There are many designs, but they're mostly similar to this one:
Sometimes the "tang" is on the crimped wire piece. Sometimes it's on the connector housing.
Old 07-19-2019, 01:33 PM   #7
Hey, thanks for that. A small rubber plug I can slit to get the wires in and then install in the hole.
