Old 11-17-2005, 09:01 PM   #1
What I use for undercoating and for touch up is stuff you get by the gallon at farm stores called "plow coat" looks like tar but is liquid like water, I use a pressure pot sprayer setup to spray it on, I spray a few light coats of the stuff it will melt into the old stuff the solvents will bond to it, messy stuff but works well, I let that dry a few days then go over it again with "foundation sealer" you get it in 5 gallon buckets at like home depot, its thick so I thin it with the plow coat until I can spray it on, you want it keep it thick as you can so you can build up thickness, again the whole thing is a total mess and it smells, what ever you spray it on will smell but only for a week or two depending on the weather, if its hot and dry it only takes a few days for the solvents to evaporate.
I bought the cheapo do it yourself undercoating kit from JC witney it works great I treat inside the doors and rockers too, the undercoat stuff they sell last about one year then it falls off.
This mixture is by far the best I have seen yet the stuff bonds and makes a water tight seal I have seen it last 10 years in wheel wells in hard Illinois winters.
When I apply this I wear cloths I am going to throw away when I am done no matter how hard you try to stay clean you get it on you :- ) Last time I did this I did my truck suburban and motor home all at one time, the bus I just bought needs a good coating so this summer I will give it a good coating.
Good luck.
hoser is offline   Reply With Quote
New Word frank-id Everything Else | General Skoolie Discussions 2 01-13-2011 03:39 PM
What do You Recommended for undercoating dentedvw Short-Bus Conversion Projects 0 03-01-2010 08:20 PM
latest post first ? putterspitt Conversion General Discussions 2 01-18-2010 09:33 PM
pjespers, what's the latest? brentag Conversion General Discussions 2 08-04-2006 10:23 AM
Upgraded Forum to latest release. Steve Forum Admin | Account Help | Suggestion Box 0 03-15-2004 03:08 PM
