Old 11-28-2018, 04:56 PM   #21
its a navistar part number so its not a door beeper or such... something else is in alarm... if the cluster goes back like dead pirate's then that beeper will stay on all the time.. if you get water leak into the gauge cluster it will beep..
also it will beep if one of your brake pedal switches goes bad.. and will set a code 247. that doesnt like the WARN light but causes that beeper to go off constantly..
if the bus hasnt been run for awhile it will beep constantly while the air is still pumping up to about 60-70 PSI..
unless your gauge panel is broken I would suggest trying to figure out why its beeping rather than just destroy it by flicking it...
check the connectors on back of your gauge cluster anbd make sure they are plugged in good and tight..
have someone with the computer interface plug in to your diagnostic connector or perform a flash code diagnosis on your own. (turn the key to ON.. press the DIAG button under the dash and the WARN LIGHT will flash you any error codes)...
Old 11-28-2018, 09:43 PM   #22
Thanks drove it today and after getting going the beeping stopped I think it may be some type of low battery warning cuz the battery seems to be affected by the cold weather on another note got it insured today so that's one thing out the way
E420 is offline   Reply With Quote
Old 12-05-2018, 04:00 PM   #23
Buzzer
It might be the buzzer that reminds the driver to check the bus for kids when they turn the motor off. See if there is a button on the inside back wall of the bus. I had to disconnect one of those before.
Lkn4it is offline   Reply With Quote
Old 12-05-2018, 04:10 PM   #24
The buzzer is a low air buzzer. Sure seems to me like the low air switch that drives the buzzer has gone bad. Examples:
https://www.haldex.com/en/na/electri...tches/be13241/
https://www.nbpsafety.com/low-air-pr...173-buzzer.htm
Juergencaster is offline   Reply With Quote
Old 12-05-2018, 04:39 PM   #25
Engine: International
Rated Cap: 7 Window 20 Passengers
Originally Posted by E420 View Post
I have this three-prong box that says buzzer it won't stop beeping any ideas no warning lights air pressure is good I have a 2001 International Harvester 3000 flat nose. Any help is appreciated thanks for your time
Probably the emergency hatch warning if you have opened it probably not shutting right I had to disable mine in the power control box by the driver.
MrBoogie is offline   Reply With Quote
Old 12-05-2018, 06:43 PM   #26
I’m thinking that the low air switch mounted on the air tank or somewhere near by is either broken or jammed or truly not getting air pressure, causing it to complete the circuit back to the low air buzzer. Examples:
Old 12-07-2018, 06:26 PM   #27
Was going to reply to your original issue until I saw the picture of the buzzer. I know on some of my door buzzers the screw that mounts it to the bus is the grounding screw. If the box isn't mounted your bus won't start. But your buzzer is under the dash, have no clue what it is for.
My bus is very similar to yours, curious to your screen name, what's the E?
Here's mine see the side.��
Old 12-11-2018, 08:28 AM   #28
Hey everybody sorry it took so long to reply I finally figured it out it's some
thing to do with a low battery is why I'm getting the beep I also think it beeps if there is low air pressure mine was beeping due two low battery when I bought the bus it only came with one battery witch has a bad cell in it I think
Old 12-22-2018, 06:08 PM   #29
Bought a second battery for the bus haven't had a problem since
Old 12-22-2018, 09:38 PM   #30
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
If you replaced it with a new battery you should replace the other as well. The old battery will kill the new one especially if it has a dead cell.
Ted
Old 12-22-2018, 10:09 PM   #31
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
What he said!
Old 12-23-2018, 03:13 PM   #32
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
Always replace in pairs. I just changed my batteries out with 31 series 900+ cca.Click image for larger version
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
