Old 11-27-2018, 08:28 PM   #1
What's with this box
I have this three-prong box that says buzzer it won't stop beeping any ideas no warning lights air pressure is good I have a 2001 International Harvester 3000 flat nose. Any help is appreciated thanks for your time
E420 is offline   Reply With Quote
Old 11-27-2018, 08:29 PM   #2
Emergency exit interlock.?
Old 11-27-2018, 08:32 PM   #3
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Sounds like the door buzzer... When a door is not closed and latched it will buzz.
Old 11-27-2018, 08:35 PM   #4
All doors shut when I open back door window or roof hatches I get a buzzer noise from the back of the bus but the beeping stays the same sometimes if I turn it off and back on it won't beep and then after second it beeping again
Old 11-27-2018, 08:36 PM   #5
I'm trying to figure out how to post a picture of the little box that beeps
Old 11-27-2018, 08:38 PM   #6
The little relay box says buzzer but it makes a beeping sound sometimes when I flick it it beeps faster
Old 11-27-2018, 08:40 PM   #7
Advance Auto and AutoZone couldn't tell me what it was or if I needed it cuz if I unplug it it stops beeping obviously
Old 11-27-2018, 08:47 PM   #8
This is the box
Old 11-27-2018, 09:18 PM   #9
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
I’m gonna guess it’s a buzzer. ;)
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 11-27-2018, 09:54 PM   #10
But it beeps and it's not what makes the door buzzing sound can I just unplug it
Old 11-27-2018, 10:08 PM   #11
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
The wonderful thing about things like this is that you can unplug it and see what happens. It won’t break anything. Kind of like removing a light bulb. If you find that you need to have the buzzer for some reason, you can always plug it back in.
To really know what it’s for, you will need to trace it back to it’s source and what triggers it.
Schematics would be a good place to start, or a flashlight and tone generator (a diagnostic tools for tracing electrical circuits - also a useful and inexpensive tool).
Old 11-28-2018, 01:00 AM   #12
This is just my first diesel I don't want to tear it up. But everything seems to be working fine without the box
Old 11-28-2018, 01:07 AM   #13
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
The buzzer is just like a CEL. It’s there to make you aware of a condition. It’s up to you to do something about the condition. To know what it’s for you need to trace it back to the trigger.
Old 11-28-2018, 01:56 AM   #14
This is the box
I am trying to remember what all of the different lights and buzzers were supposed to warn the driver about some sort of condition that needed attention.
Every emergency exit door, hatch, and window had some sort of alarm. The roof hatches in particular are sometimes really hard to get the buzzer to quit.
Low oil pressure should stop buzzing as soon as the oil pressure goes over 5 PSI.
Low air pressure should stop buzzing as soon as the air pressure goes over at least 60 PSI and it may stay buzzing up to 90 PSI.
Some buses had a headlight buzzer if you didn't turn the headlights off when you turned off the key. Others had a buzzer that would only go out after the headlights were turned on whenever the key was in the run position.
Some buses had seat belt warning buzzers the remind the driver to put on driver's seat belt.
Some buses had a buzzer for low fuel.
You are going to have to start going through the electrical panel and start turning circuits on and off so that you can find which circuit is powering the buzzer. Once you find which circuit it is on you should have a better idea as to what the buzzer is telling you to check.
Good luck and make sure you post what the buzzer was reminding you to do!
Old 11-28-2018, 05:09 AM   #15
Coachwork: Gillig
I had a buzzer like that, I think...? I removed it... probably.
Just remove it; what could go wrong...?
ComfortEagle is offline   Reply With Quote
Old 11-28-2018, 01:08 PM   #16
Thank you cowlitzcoach and everyone else I'm going to start going through and see If can figure out what's up wit it
Old 11-28-2018, 02:38 PM   #17
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
It's a buzzer for several things. Including low air. I just unplugged mine. The instrument cluster went out and the alarm wouldn't stop. So it had to go.
Dead pirate is offline   Reply With Quote
Old 11-28-2018, 02:38 PM   #18
Coachwork: myself
Chassis: amtran
I have the same bus. Sorry. I should have said so.
Old 11-28-2018, 02:40 PM   #19
Coachwork: myself
Chassis: amtran
[/QUOTE]
Old 11-28-2018, 02:40 PM   #20
Coachwork: myself
Chassis: amtran
Hilarious.
