Old 11-01-2017, 09:17 PM   #1
Year: 90
Chassis: international
Whats your axle ratio
Just wondering, With 11r/22.5 tires, what ratio is your rear end and how does it do at hiway speeds? I have 4.78 gears and are considering a change for better hiway speed. What do you have and what rpm are you at 60 mph?
Old 11-01-2017, 09:52 PM   #2
Chassis: International FE
Rated Cap: 84 passengers
My bus has a MD3060 transmission in it, 5th gear is overdriven at 0.75:1. My rear axle gear ratio is 5.38:1 I believe. I want to say at 60 mph my bus is running around 1800 rpms.
rensch26 is offline   Reply With Quote
Old 11-01-2017, 10:40 PM   #3
Alan N's Avatar
Year: 1975
Chassis: Gillig
I have 5.29 rears
11/24.5 tires
And .78 overdrive
2000 rpm gets me about 63 mph
Alan N is offline   Reply With Quote
Old 11-01-2017, 11:20 PM   #4
Year: 90
Forgot to mention, my trans is 1-1 in hi gear.
Old 11-02-2017, 12:10 AM   #5
Asetechrail's Avatar
Coachwork: Amtran Genesis
11r22.5 tires...4.78 rear gears...1:1 final drive on transmission...
60 mph is 2370 rpm
Would really like some 4.11 rear gears for 70 mph at the same rpm or 60 mph at 2025 rpm
Asetechrail is offline   Reply With Quote
Old 11-02-2017, 01:42 AM   #6
Chassis: IH
I currently have 5.38 gears, 1:1 high gear transmission (it's a 5-speed manual), 10R22.5 tires, 55 MPH top speed at ~2500 RPM on a T444 engine.
A swap to 4:11 (or faster gears) is planned. The speed may be electronically limited in addition to the RPM governor. If so, it will be removed when the computer is reprogrammed for the new gears.
Old 11-02-2017, 11:19 AM   #7
OldSkoolRacin71's Avatar
Engine: T444e
11r 22.5 tires. Allison at545 transmission. T444e. Rear end is 4.44 gears. Governor has been killed by Intl dealer. Will run down the highway at 70mph if I let it.
Sent from my SM-G955U using Tapatalk
OldSkoolRacin71 is offline   Reply With Quote
Old 11-05-2017, 10:40 PM   #8
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
DT466E AT545 tranny. 295/75 R22.5 tires. 70MPH @ 2600RPM. Prefer to cruise around 60-65
Sent from my SM-G900V using Tapatalk
johnbloem1974 is offline   Reply With Quote
Old 11-05-2017, 10:41 PM   #9
Rated Cap: 16
Oh, and rear is 3.98
Old 11-05-2017, 10:42 PM   #10
Rated Cap: 16
Would love to have a 2000 or MD3060....
