Old 04-22-2018, 12:53 PM   #1
Wheel Arch problem in Floorplan
Hi Guys,
I started my Skoolie project may 2017 with orientation etc, after buying, shipping to Europe and all kind of governmental requirements etc I finally got my license plates and started with the conversion it self.
In the meantime I started with the floor plan design (see attached).
I currently 'taped' the floor plan on the bus-floor to actually see and feel how the design would work out.
Most of the design still feels great, except one thing, the 'bathroom-entrance', which is exactly at one of the wheel arches.
Any ideas are welcome!
Regards,
Kasper
(The Netherlands)
KasperNL is offline   Reply With Quote
Old 04-22-2018, 12:59 PM   #2
Some more details, my bus is a 1997 International / Thomas 3800 series with a 71 passenger capacity, 11 windows.
Old 04-22-2018, 01:14 PM   #3
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I am planning on putting my toilet on the wheel well. It's just a step up. With the position of your shower, it makes for a nice step down to the shower.
Nick
Old 04-22-2018, 07:14 PM   #4
Also...on most Skoolies you can "chop" the wheel tubs down a fair amount. Look down below and see how room there is between the axle and the bump stops. You will typically have quite a bit more space between the tires and the top of the well. You can cut them down by that amount without fear of rubbing.
I cut about four inches off the front of one of mine to make room for the potty. Still a ton of space.
Old 04-22-2018, 07:46 PM   #5
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Not to detail the thread, but I'm curious what shipping cost you.
Whatthefak is offline   Reply With Quote
Old 04-22-2018, 08:16 PM   #6
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Nice bus you got there! Looks just like mine. Our layout looks fairly similar, although mines not finalized yet. I think how I will be getting around this problem is by separating the shower and toilet. I won't have counters on both sides so I think I'll be putting my toilet just in front of the wheel well on the opposite side as the shower. Composting toilet so no need for plumbing.
Also, on my build page I posted my layout a few days ago. The toilet worked behind the wheel well because I was going to have a washer/dryer in the front by the fridge. I've decided to not do the washer though, and move the toilet leaving me more space in the bedroom area and shower
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 04-22-2018, 10:31 PM   #7
I bought the bus in Nebraska, so I had to rent a driver to drive the bus 1400 miles to Baltimore which costed me: $1998
The shipping Baltimore to Antwerp was $3490 using Hoegh Autoliners.
Everything was arranged by Landstar / Deakins Logistics Group - Florida, including the customs, export etc
Old 04-22-2018, 11:47 PM   #8
Year: 90
Chassis: international
I'm not seeing a bathroom sink. What is the box marked wm? seems you can move the entire bathroom rearward with no problems to clear the wheel well. what about tank placement under the toilet?
Old 04-22-2018, 11:49 PM   #9
Theres indeed no sink in the bathroom at the moment, not 100% if i want / need one since the kitchen is very close.
The 'WM' box in the back / garage = Washing Machine.
Old 05-08-2018, 02:28 PM   #10
After onsite puzzling with tape on the floor we've found a 'solution'.
I moved the bathroom and inverted the position of the shower and toilet within the bathroom, I also rotated the main bed 90˚.
After this onsite job I went back to the computer to apply the changes to the 'design' (attached)
