Old 10-24-2018, 04:34 PM   #1
Chassis: Thomas 35'
Engine: Ford Diesel
Wheel Wells
Has anyone shaved down their rear wheel wells? Looking to gain access room. sjm
woof5400 is offline   Reply With Quote
Old 10-24-2018, 07:50 PM   #2
plfking's Avatar
Rated Cap: 34
ol' trunt did an excellent job on his.....4 or 5 posts down.
http://www.skoolie.net/forums/f13/di...bed-15756.html
Don
The Busted Flush
Old 10-24-2018, 08:07 PM   #3
Me...I just cut a notch out of one to help fit my bath & potty. Could probably have gone flat across the top but the idea of some off roading kept me conservative.
Old 10-24-2018, 09:05 PM   #4
DreamWeaverBus's Avatar
Nicely done! My bus is at the welders right now to get the wheel wells patched, I think I'll stop by and see what he's doing tomorrow.. might mention this to him..
DreamWeaverBus is offline   Reply With Quote
Old 10-25-2018, 10:39 AM   #5
Measure twice, cut once. My bus has 22.5" wheels/tires that are above the floor line at parked. If I went to the smaller 19.5, they would still be above the floor line.
Old 10-25-2018, 11:22 AM   #6
If considering lowering your wheel well tops...
1. Measure from the top of the tire to the inside of the well
2. Then measure how much travel is possible from the axle to the "stop". Allow another half inch for hard compression and you should have the upper most travel limit for the tire. From there you can see how low you can go.
