09-22-2017, 11:30 AM
Chassis: International CE 300
Rated Cap: 71 passenger / 12 window
When did they start making 78" buses? And which buses are CHEAP to operate?
The more I learn about school bus conversions, it seems the more I have to learn.
It would help me narrow down my search if I knew when they started offering 78" interior floor-to-ceiling height as an option in school buses. If you don't know when that FIRST became an option, what is the oldest bus you've ever heard of or seen that had 78" interior height?
Also, I need some direction on cheap maintenance. My wife and I are NOT made of money. We're traveling musicians. I have read other threads that talk about "BOAT" ("Break Out Another Thousand") when repairs are needed, and that would bankrupt us and/or drive us to as-yet-unseen heights of anger. Someone mentioned that certain engines cost ~$12,000 for a complete in-frame rebuild, and some transmissions cost ~$5,000 for replacement.
Yet, someone else told me on my AT545 thread that you can find used AT545s for free (I saw that myself) and that a replacement job on one shouldn't set someone back more than about $1,200. That I could handle, for a transmission. I'd even be willing to double that, if I knew that the transmission would last a long time... I will spend what I MUST spend... but I'm trying to figure out if I MUST spend all of that money that people are talking about. (Someone said $5,000 per year, average, for maintenance. I'd sooner not have a bus.)
Someone mentioned that their bus engine uses 29 quarts of oil. That's an enormously expensive oil change, in parts alone!
If I were willing to sacrifice top speed (I really don't see needing to go above 55 mph, but I'd be pretty bummed if I couldn't see the north side of 50 without red-lining the drivetrain on the bus... and I'd be okay with crawling up steep hills, which is what I did in my class C just to avoid overstressing the drivetrain) and I were okay with a manual transmission (which I am) and I were okay with something old (which I am, as long as it's tall enough), is there a bus type out there which is likely to be inexpensive for maintenance? I don't want to be paying $200+ for an oil change every few thousand miles. I don't want to pay $12,000 for a new engine if it needs one (and every vehicle eventually blows its engine). I don't want to pay $5,000 for a new transmission. I don't want to pay "another thousand" every time it goes into the shop. I don't want to, because I can't. Being a musician is fun, and what we do certainly brings joy to a lot of people, but it ain't lucrative. I anticipate putting several thousand miles on the bus per year, and I don't want to be spending thousands of dollars annually just to keep it operational. Anything that'd cost $700 or more, in my opinion, should be a "one and done" job that won't have to be done again for another ten years at that accumulated mileage rate. (For an ordinary car, anything that costs HALF that much is a "one and done" job.)
But, alas, it would have to be 78" tall, and I doubt we could do much with a short bus. I'm okay with a mid-length (~45 passenger) bus... in fact I'd probably rather have one that size... but I'd take full-size before I took shorty. A shorty just wouldn't have enough room for our needs.
Any ideas?
09-22-2017, 12:02 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
My home costs considerably more than 5,000 a year.
Rent would cost more. Pay yourself "rent" every week for maintenance. As far as height ... My 2002 AA is a tall ceiling bus. A 545 is a stout transmission for a stop and go school route, but it isn't really great on long trips or inclines. It never locks, so there is always slip causing heat build up and wear. A 643 has a lock up and 1:1 fourth gear... Solid trans.
If you aren't mechanically inclined, most repair jobs are going to be expensive, but basic maintenance isn't hard to do on your own... Oil change, coolant change/flush, trans service, belts...
Look for as little rust as possible.
The Cummins 5.9 is often categorized as "under powered", but the parts to repair it are prolific. Any rebuild of any engine is going to set you back +5000.00 and probably more.
Do your research, pay to have your bus inspected prior to buying, it could put high repair bill off for years.
Make a list of what you absolutely must have, what you would like, and what you don't want. Odds are you will come across something close.
09-22-2017, 12:09 PM
Chassis: IH
I'm not sure when 78" ceilings became available on school buses.
As for maintenance and repair costs, that's another matter. I would avoid Cat engines not because they are "bad", but because you can only get parts from a Cat dealer and usually at a premium price. Some parts are simply going to be more expensive than their car counterparts because they are so much bigger, such as tires. Some parts will be fairly priced, because of mass production and how common and widely available (air brake drums and shoes, for example). It's true some engines use a lot of oil. I have a T444E in my shorty which I believe uses 16 or 20 quarts of oil (I have yet to do a change on it). A DT466 or 8.3 Cummins uses somewhere around 20-24 quarts per change. I also drive a Volvo road tractor with a 13 liter engine which holds somewhere around the 40 quart mark. Yes, that's somewhere around 10 gallons of oil. The company we lease it from has it on a 35K oil change schedule (yes, that's a lot of miles), and I don't think I have ever driven any diesel that saw oil changes less than 15 or 20K miles apart.
Perhaps the one thing that adds the most cost to getting anything done is labor. A DT466 can be rebuilt for somewhere around $2000 in parts and such, a shop will tie up a lot of labor and that's where things add up quickly. Learning how to, and doing much of the work yourself will save you a fortune on keeping a bus going. These school bus transmissions are pretty common and I expect most models can be rebuilt for far less then $5K ... I can get a trans replaced in the Volvo for somewhere around $2500 and that includes labor. The likelihood of it having a failure is very low (it's an Eaton 10-speed), it should easily last well over a million miles.
I think your best bet will be to look for a wheelchair-lift bus as many (not all) have 78" ceilings and they come in various lengths from shorty to full size. A DT466 or Cummins 8.3 should serve you well and they're fairly easy to work on. The T444 engine is good too (I have one), but not as powerful as the others. Manual transmissions aren't common in school buses (said by the one who has that very thing!) but should you manage to snag one, it should easily last the life of the bus. The automatics are pretty good too and if kept serviced, they should last a very long time.
09-22-2017, 04:38 PM
Don't discount the 5.9 Cummins 12 valve mechanical engine.
09-22-2017, 04:51 PM
I kind of thought that the Cummins 5.9 would be likely to be affordable to repair, along with the T444E... if for no other reason than because they're the same engines that were installed in pickup trucks of their era.
09-22-2017, 05:57 PM
They're both ok, but both WILL cost more to rebuild than a 466 or 8.3, and are just outclassed and outgunned.
09-22-2017, 06:28 PM
How much will a 466 or 8.3 cost to rebuild?
T444E rebuilt engine: $3,995 T444E NAVISTAR DIESEL ENGINE | eBay
Cummins 5.9 rebuilt engine: $4,000 5.9 cummins engine long block 03-07 | eBay
Cummins 8.3 rebuilt engine: $7,950 REMAN Cummins 8.3L 6CT Diesel Engine Mechanical Fuel Pump CPL# 1566
DT466 rebuilt engine: $4,800 DT466E NAVISTAR LONG BLOCK ENGINE | eBay
Admittedly this doesn't account for how the Cummins 8.3 and DT466 can be done in-frame, but I tried to account for it by not including the refundable "core charge" in the prices for the Cummins 5.9 and T444E. The prices also don't include shipping, but I imagine that shipping would be factored in if a diesel shop were to order parts or a new engine for a bus that needed an engine job.
I guess I don't see how the latter two engines are cheaper to rebuild... nor how an engine rebuild can cost $12,000 or so. Do these numbers look uncommon?
09-22-2017, 07:08 PM
Chassis: Bluebird
Rated Cap: 72 pax
The 8.3 and 466 usually do not require the old block to be removed. Parts are probably the same, but labor to remove and machine the 5.9 and 444 will be higher
The 8.3 and 466 have wet sleeves. As long as the mains don't need to be machined, the entire rebuild can be done "in frame"
09-22-2017, 07:27 PM
Okay, so what is a reasonable price for a rebuild on an 8.3 Cummins and a DT466?
And when you say "as long as the mains don't need to be machined"... I don't know what you mean, but after 300,000 miles or however many it takes for the engine to wear out completely, wouldn't you think that anything that might have to be machined WOULD have to be machined?
09-22-2017, 07:34 PM
Chassis: Bluebird
Rated Cap: 72 pax
The main bearings on the bottom end. They only have to be machined if they wear through the bearing. At 300k I would expect to have the heads checked and possibly redone, change the sleeves (the cylinders are lined and can be replaced) and inspect/replace the cam, new rings, freeze out plugs, inspect pistons (replace if needed). And probably about a hundred little things (like seals and head studs) that need to be replaced.
It isn't hard, but everything is heavy and there are specialized tools.
09-22-2017, 07:52 PM
our schools bought 78" busses in the mid 80s, carpenter styarted offering it in 1986, ive seen some late 80-s / early 90s Amtrans that were tall..
I believe Wayne was always a 78" height..
busses have been offered in both heights and still are.. so you cant just judge by age... there are brand new 2018 IC's out there that are in both 72 and 78 height.
09-22-2017, 09:44 PM
You guys are getting lost!!!!! No logic to paying all these overhaul and replacement costs.
I want a bus that will get me down the road safely economically etc. and you can buy busses cheap that will never need you to give up the gold.
Start off with a solid bus with great tires, solid exhaust, very little rust etc and get to converting it.
Thousands of buses out there with less than 150k miles. Rare a catastrophic event with these old trucks.
09-22-2017, 10:46 PM
Chassis: IH
Doing it yourself inframe, an 8.3 or DT466 should cost somewhere around $2000-2500 for parts and supplies (oil, coolant, etc). At a shop, anything above that is labor, shop supplies, and taxes.
$12K (at a shop) for an engine rebuild isn't unheard of in the big truck world. That's about what I'd expect for an ISX Cummins which is like 15+ liters and can be cranked up to like 600 hp from the factory. It's also a dual-overhead cam engine so the head work alone is like $2K or so.
The 5.9 Cummins and T444/7.3 have to come out for a trip to the machine shop. The larger sleeved engines, not so much. It's pretty rare they need bottom-end machine work, unless something went catastrophically wrong or was driven extensively on a "spun" bearing (somewhat rare, it will knock/rattle rather obviously as well as not hold much oil pressure when this happens).
09-22-2017, 11:43 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
OP: And which buses are CHEAP to operate?
I've found our City buses are very reasonable at $1.50 / ride. Other than that, this thing is a money pit.
I think the order from most to least costly goes:
- Airplanes
- Mistress
- Boat
- RV
- Children's College Education
09-23-2017, 06:05 AM
Is there, somewhere, a detailed step by step set of instructions for rebuilding one of these engines? I've never rebuilt an engine. The most engine work I've ever done is a tune-up and a carburetor cleaning.
What could an 8.3 or 466 rebuild cost at a shop?
What is a "spun" bearing? (I was reading that rebuild shops often won't accept as a "core return" an engine that had a spun bearing. Hell, I don't even know what a main bearing is. If it's on the bottom end of the engine, my guess would be that it's the bearing where the piston meets the crankshaft. How close am I to being correct?)
09-23-2017, 06:11 AM
It's one of those "you never know" issues. The one thing guaranteed with any motorized vehicle is that it will, at some point, require repairs. Low mileage doesn't even mean much. My RV (with T444E, I think - 1996 Power Stroke 7.3) started hiccupping and nearly left me stranded a few times, at just over 70,000 miles, due to the camshaft position sensor having failed. That set me back $700. (Okay, it could've been only $450, but that's another thing. Shop #1 replaced several parts that didn't fix the problem. Fortunately, the guy was an honest mechanic and didn't charge me for labor because he didn't fix the problem, but mechanics like that are rare. Shop #2 fixed the problem but it was $450.)
A bus may look solid, have no rust, have good tires, and run and drive just fine for a while... but be hiding some mechanical weakness that will come out eventually and leave you with an expensive repair. I've heard people say "Break Out Another Thousand"... well, that's a lot of money for us.
09-23-2017, 06:14 AM
If you do it yourself an in-frame rebuild kit is $1200 for a DT466. Oil is $30-$50.
09-23-2017, 06:27 AM
The main bearings are the ones where the crank is at the block, front and rear and several along. Rod bearings are where the piston rod attaches to the crank.
The metal block and crank have big caps at each bearing point.if you take the cap off it exposes 1/2 of the crankshaft itself, nice and shiny. The bearings themselves are 2 piece inserts.take a piece of paper and bend it in half but don't fold it, that's the shape. The bearings slide between the block and the top half of the crank and one inserts in the cap. To cup the crank.
As the crank spins these bears do not, they stay put with the block,
The bearings are softer metal and thus will wear before the metal crank, idea is that bearing inserts are cheap, cranks are not. So you simply replace these metal inserts in a rebuild.
If you lose lubrication ie run out of oil, the bearing and crank get extremely hot .. friction, the bearing inserts and crank way expand so much that it effectively presses them on the crank .. more friction and may partially melt the bearing to the crank. The bearing now is attached to the crank more than it is to the block and so bearing and crank spin inside the block.. result usually is permanent damage to the crank and the block.
09-23-2017, 06:44 AM
A correctly done infrane , you need to send your head out and have it worked, unless you can measure warpage yourself and put it back together so the head gasket doesn't leak, chances are your valves have some wear..
Idea is you want a reliable drive anywhere bus, don't halfass your mechanicals, rebuilding an engine is well within the reach of someone with general mechanical skills, but patience and care to measure and inspect parts and torque wrench your bolts and clean-clean-clean!!!!
I've out plenty of engines together in my home garage with pretty standard tools.
However certain parts you need the specialty tool!!! You don't just beat cylinder liners out, you don't just squeeze rings into the cylinder .. seals only work on clean surfaces .. or they will leak.
As for failures, they are machines, machines old and new can break, in April I replaced a bunch of cooling and belt related items, tested all my idlers pulleys etc all seemed perfectly smooth and tight. Weds an idlerbearing seized and put me along the road, it happens.. ya gotta have tools, resources and yeah some extra $$ for unplanned breakage.
If machines didn't break then there wouldn't be dozens of mobile truck repair rigs jreadyvro roll along every major freeway in the USA
Christopher
09-23-2017, 07:49 PM
I have appreciated the dialog here because I am interested in both of the op's questions - the height and the expense. I am looking for as tall an interior as possible. I am also looking for a bus that will comfortably cruise on flat land at 70 mph, more likely 65. I have read several posts on several forums of people that say they can do this in a 35+ ft bus with a 6bt after changing the rear end gears. (Any comments on this?)
A quick google revealed a few companies that will provide rebuilt long blocks, 6bt, for a little more than $4,000 Do you think this route is better than having a local mechanic do it - better can be lower price or better quality? I think I am competent to disassemble something..might lower the price a bit, and might even be able to remove the engine with the help of some good backyard mechanic friends. With the rebuilt, I would not want much more horsepower, but would lean to things that provide more torque, give better mpg and make the engine more durable.
I, also, am not related to either Warren Buffet or Bill Gates, but I was thinking that if I get something that looks aesthetically good, it has probably had good maintenance all along. I was also planning on dropping about $10 into the drive train - hypothetically speaking, it will last for the remainder of my use (100K miles) without breaking down, and will give me the lowest cost of operations possible. It may cost $85 to replace an injection if I do it myself in my yard, but might cost $300 or more to have it done if the bus takes a dump on the interstate, not including the cost of towing. Like any used vehicle, there is usually a reason why someone is selling it. I may change my thinking once I find the bus, but this these are the thoughts I have while walking into this situation.
When you talk about engines you talk about wet sleeves? What does that mean? AFAIK, the 6bt has sleeves that can be pounded out of the block without having to machine the block (unless there has been some damage to it).
