Old 05-25-2019, 08:22 AM   #1
Engine: International 3800
Rated Cap: 72 passenger
When you..
When you guys closed up your holes in the bus floor, I know there are many different ways to get it done. I don't have a welder or budget for one right now. Was going to silicone after the first paint layer, but I hear it's not the best on the bus lol.
Seen another guy used flex tape to swap up the holes and any extra ones. Thought that might be better than f$@&#ing around with Bondo and crap. So please share, I'll be cleaning and primer this weekend and painting starting in the week 🤩🤩🤩 so pumped
90sKidFatherNow is offline   Reply With Quote
Old 05-25-2019, 09:49 AM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
A penny for your caulks...
No, seriously- Lay down a small doughnut of caulk (non silicone) or JB Weld, then smoosh a penny into it to seal the bolt hole.
Now I hear your next question: "Do I want to use pennies minted before 1982, or those struck later..?!!"
A valid question young feller.
Post-'82 are copper clad zinc, earlier pennies are pure copper, arguably making them more valuable for scrap than their putative face value.
Dielectric concerns are probably non-existent, since the coins are insulated from the floor by the fixative.
Hope this made cents...
Old 05-25-2019, 11:18 AM   #3
Construction adhesive and pennies is what I did, quick, easy, cheap.
I actually welded a few up and said screw that, gonna take too long.
Old 05-25-2019, 11:53 AM   #4
First off thank you to both of you guys for replying and giving input!
Turns out I did buy some construction adhesive so far Gorilla hasn't failed me! Don't have enough pennies but I'll just cut little bits of metal.
Old 05-25-2019, 12:05 PM   #5
Everything I've used that glue on I was disappointed. It seems like it expands quite a bit while drying and ends up running a foamy access.
Old 05-25-2019, 12:35 PM   #6
for me JB-weld or bust... I know that stuff gets a bad rap on here. but I Like JB weld esp on stuff thats a little dirty much better than gorilla glue..
if using metal you can use 550 seam sealer, that stuff sticks to anything..
Old 05-25-2019, 01:03 PM   #7
HazMatt's Avatar
I'd splurge if'n I was short on cents, and use whatever change I could scrounge up. What's your time worth, scrimping and snipping scraps?
Obviously, since I'm a Skoolie, I am short on sense...
(Never seem to suffer shortage of cents)
Nothing but love for da G Glue. In an appropriate application...
It sez upfront that it expands while curing. The trick for me has been scraping it thin enough not to deform the join while thick enuf to immobilize what I want to not ever again move, easily...
Like the foregoing Go-rilla reply, JB Weld works, so long as too much isn't expected of it.
Not recommended for, say, mending a cracked connecting rod, or adhering roof deck pilings...
Old 05-25-2019, 02:17 PM   #8
JB Weld is too expensive for that application IMHO.
Old 05-25-2019, 02:30 PM   #9
I figured I'd just put the appropriate layer or amount at a time, says it's good for gap filling too but I don't mind to cut a scrap metal and adhere it down. But if it's does the gap filling good enough I'll just do that on the bolt holes, than a final layer of paint over top after. Just value the time cutting the metal up and not dealing with the kids haha
Old 05-25-2019, 02:36 PM   #10
Sleddgracer's Avatar
Chassis: still looking for my bus
check this thread for floor patching
http://www.skoolie.net/forums/f13/an...ese-26316.html
