Old 03-13-2011, 05:35 PM   #1
where is the flasher??
I know this may sound dumb, and I did try the search, but where is the flasher for the overhead warning lights? I removed my panels where the switchs are wnd listen to see if I could here them but no luck. also what would it look like? I know what reg ones are like, but not sure on a bus.
1999 blue bird full size t444e. My clear lens sould be here monday so I want to get them rigged up weather permitting.
tks
Old 03-13-2011, 05:41 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: where is the flasher??
Don't know for sure, but probably main electrical panel accessed from outside beside driver.
That's where it is no my RE and also on a Thomas I did many years ago.
Old 03-13-2011, 05:49 PM   #3
I dont have outside panel, I slowly just keep looking, tks
btw, I put this in the wrong spot, should be under conversion
tks
Old 03-13-2011, 07:00 PM   #4
found it!!! didnt know it was the flasher! its just a board with about dozen wires, there marked , now ill just have to figure out how to wire so they stay on,its will take a bit time, but it will be worth it to have some extra lighting.
tks for the help
Old 03-16-2011, 11:52 AM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
tks for the help
Hey gbstewart, I don't suppose you could snap a picture of that board on which the flasher is located? I will be deactivating my flashers as well, and maybe you could save me the headache of trying to find it.
Thanks,
Dan
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-16-2011, 10:44 PM   #6
Thanks,
Dan[/quote]
no problem, I ll take one tommor, and post it.
Old 03-17-2011, 01:51 PM   #7
ok Dan, here is where the flasher was for mine,
Old 03-18-2011, 02:20 PM   #8
Diesel Dan's Avatar
Engine: DT466/AT545
Thanks gb, I never would have thought that was a flasher! Good to see a pic, so if I find something similar I won't disregard it.
Gallery:
Conversion Thread:
Old 07-10-2019, 11:03 AM   #9
for the hazard/warning lights on the main chassis. reach around the turn signal stick, a push button is on the back side of it.
Cool bus is offline   Reply With Quote
looking for 4 way flasher/turn signal relay syke Conversion General Discussions 13 05-24-2012 01:40 PM
Flasher lights... traveling thru states lornaschinske Conversion General Discussions 6 07-06-2010 10:50 PM
Interior roof & Flasher removal Papabear Conversion General Discussions 1 02-18-2009 09:40 AM
Does anyone have a flasher schematic? odyssess Conversion General Discussions 7 11-13-2007 06:38 PM
how to Cut out the FLASHER RELAY IN THE RED LIGHT. batilzown Conversion Tutorials and How-to's 12 10-08-2007 06:50 PM
