Old 12-22-2004, 08:49 PM   #1
Where to get house batteries cheap??
Im in need of my batteries now and would like to know where to get them cheap.
In search of Bus #2
(Sold)1989 Chevy Thomas 8.2 Detroit Allison AT545 Custom 3rd door added in back.
GM Service Tech
JonCBrand is offline   Reply With Quote
Old 12-26-2004, 01:59 PM   #2
Send a message via Yahoo to phillip266
House
iam not shure whats in your area but i have goten some at a few battry shops around just make shure to tell them you need house and not name brand hope this helps
PS dont do the truck stop think thire outragesdly high priced thire
Cool things happen when Great Minds come togather :)
phillip266 is offline   Reply With Quote
Old 12-26-2004, 02:20 PM   #3
House Batteries
Hi There, You might want to think about trying Wally World. Quite a few of the bus conversion guys from other BB are using Wall World Batteries. I do not know the nomenclature for the best buy or brand that they carry but I am sure that you could do a little snooping around and find out. 12 V and pretty cheap with good quality. Something to think about?
J.B.
J.B. is offline   Reply With Quote
Old 12-26-2004, 03:09 PM   #4
12v on a Diesel
? i was thinking that the battres would be 24v like in the biger trucks ect if so wal-mart will be a hard place to find them but if thire 12 v wal-mart is the way to go anyone know if the Diesel bus use 12 or 24v?
Old 12-26-2004, 09:59 PM   #5
Batteries
In My opinion 12 V is the way to go. I you want 24 V then take two 12 V and hook them together.
J.B.
Old 12-27-2004, 12:15 PM   #6
As far as know they use two 12v batteries to make 24 volts. Most modern (1980s and newer) skoolies are 12 volt. 24 volt systems work great except the light bulbs cost more and almost everything is designed for 12 volt use.
busone is offline   Reply With Quote
Old 12-27-2004, 02:13 PM   #7
12 volt/24volt
Hi There Phillip 66, What voltage is your bus . I think you need to start there. Sometimes the KISS method works alot better than the complicated method . Let me know the voltage.
J.B.
Old 12-28-2004, 07:58 PM   #8
What is o'reillies
In search of Bus #2
GM Service Tech
Old 12-30-2004, 07:17 AM   #9
lapeer20m's Avatar
i'm a big fan of 6volt deep cycle batteries. The ones meant either for golf carts, or electric fork trucks. Connect pairs of them in series to make 12 volts. These batteries are not cheap, but are the best in lead acid batteries when it comes to running accessories in your skoolie when the engine is not runing.
If you use automotive batteries, or wal-mart marine/deep cycle/RV batteries, you're getting what you pay for. These types of batteries are not meant to run inverters and other loads for long periods of time or to be drawn down below 12.3 volts resting voltage (12 volt batteries are actually ~12.6 volts when fully charged. You should never let batteries drop below 12.3 volts resting voltage!) Sure you can make it work, but as far as lead acid batts go, you can beat the performance you get from deep cycles.
Trojan makes some of the best deep cycle batteries. http://www.trojan-battery.com/GolfDC.asp?Product=51
IF you plan to keep your skoolie for 5 or 10 years, it's worth it to make the investment in good batteries. In the long run, you'll spend more money replacing cheap batteries than you would have if you purchased the correct batteries in the begining.
for all kinds of info on batteres, go to http://www.phrannie.org/battery.html
Next thing to consider: How to charge them properly............
In my opinion, creating a 24 volt "house" system doesn't make good sense if you're bus is already set up for 12 volts. In theory, 24 volts is a better idea than 12. Current can be carried in smaller guage wires, motors run more efficiently ect.......however, there is a problem: we currently live in a 12 volt world. Almost all accessories commonly available today for any vehicle in north america are for 12 volts. Fuses, lights, fans, motors, inverteres, relays, phone chargers,coolers, refers, ect are almost exclusively 12 volts.
Old 12-30-2004, 07:44 AM   #10
lapeer20m's Avatar
This is more usless trivia than useful information:
another big advantage of 24 volts that i forgot to mention: You can get twice as much power from the same alternator in a 24 volt system as you get from a 12 volt system.
For instance: A 100 amp alternator can make 100 amps at nearly any voltage up to and above 100 volts if you make some simple modifications to the voltage regulator.
100 amps @ 12 volts = 1,200 watts total power
100 amps @ 24 volts = 2,400 watts
The amperage rating stays the same even as the volate increases.
For lots in interesting reading on the subject, visit this site http://members.1stconnect.com/anozira/S ... rnator.htm
12V electrical to house and start batteries John Brothers Electrical, Charging and Solar 8 02-27-2014 12:56 AM
House batteries placed inside? jkronmiller Conversion General Discussions 3 12-25-2012 10:18 PM
House Batteries Stuff Electrical, Charging and Solar 12 06-06-2012 08:52 AM
Where to get cheap batteries? phillbus914 Electrical, Charging and Solar 3 11-29-2008 10:22 PM
House batteries JonCBrand Conversion General Discussions 2 11-30-2004 09:30 PM
