Old 03-14-2007, 11:10 AM   #1
eggman's Avatar
Fist off, welcome to the madness.
Second......to find out the rear axle ratio, take your vin to the closest IH dealer and they can look it up on the build sheet. You can call, but when you are face to face with them, they will usually let you have a free copy of the build specs. They come in pretty handy later on as well. Could be a corporate axle, which could be an International, but Dana and Spicer are the same.
One place that I buy axle shafts and ring and pinions from is Randy's Ring and Pinion http://www.ring-pinion.com . They may not have what you need, but they could tell you what you have.
To change out the rear ring and pinion, both axle shafts would have to be pulled out far enough to clear the removal of the carrier. Drive shaft would have to be removed to pull the pinion shaft out. It will be a fairly big job. A very important one. Myself, I would leave it to a professional shop, if you have never done one before.
Hope this helps.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 03-14-2007, 03:30 PM   #2
Most truck differentials are the carrier type, the ring and pinion a.re installed into a cast iron carrier that bolts into the axle housing, do the dealer build sheet like eggman suggested, then remove an axle shaft and mesure the diameter and count the splines on the diff end. With the axle make and model and spline count a truck salvage yard should be able to help you out with a replacement exchange differential unit. If you don't have any luck locally, google goody's truck parts in toledo oh. they are very helpful and will ship parts.
Old 03-14-2007, 10:17 PM   #3
Engine: 7.3 diesel
My numbers on mine are close to yours.
13392A
029CA104-2X
5.57
Now I also found the line ticket that shows
Spicer f155s 15.5# SGL Reduction Axle 5.57 Ratio
Old 03-14-2007, 11:53 PM   #4
crazycal's Avatar
Welcome. I love it up there. I own a lot in Shelter Cove (a buildable one) and hope to build a house up there someday. Sorry I can't help you with your rear end question. I do second Eggman's advice about having a shop doing the swap.
I'm hungry!
You Gotta Let Me Fly
Old 03-15-2007, 03:15 PM   #5
eggman's Avatar
Originally Posted by norcalgold
OK, I crawled under the bus looking for numbers and found a tag on the axle. We dont have any truck shops that deal in International so I will wait till I get to a bigger city on a trip or try Goodies' or do a search for someplace closer.
Here is the info off the tag:
spicer
dana
23588A
029CA101-2X
ratio 5.57
cast into the house near the yoke was:
07221
4C or 4G
68943-R4
Looks like it is a dana rear end. I guess some of the other numbers will determine the model of the axle.
Thanks for all the info.. if anyone can decepher what these numbers mean, that would be great. The tags ratio of 5.57 matches the line tag.
Gerald
(still trying to come up with a bus name.. "Old Goat" comes to mind
norcalgold and wmah,
Here are your answers.
Of all the numbers listed in your posting, the only number that was close that Dana could use was the 029CA101-2x....Which could possibly be 029CA104-2X. When the tech pulled that number up, this info is what he gave me:
Diferential case break between 4.33 and 5.38 ratios and 5.57 and 7.17 ratios. Which means that you can not use the carrier from a 5.57 rear end to mount your wanted gearing of 4.44 (which isnt available anyway).
Your axles ratios list is as follows: [4.33, 4.56, 4.78, 5.29, 5.38] using one carrier and [5.57, 6.50, 7.17] using the larger carrier.
Spline sizes: 3.228" x 36 splines, however different lengths....38.62", 40.25", and 40.60" depending on the hole type, straight or tapered and if it is the F155 or the F170 axle.
The tech also gave me a website that lists your axle's illustrated parts list, which is for the F155-S as well as the F170-S axles.
The first one is the list of manuals.
http://www.roadranger.com/Roadranger...Language=en_US
The second one is the specific manual for the F155-S and the F170-S axles.
http://www.roadranger.com/ecm/groups..._axip-8663.pdf
This one is for the service and sales literature....covers brakes and other things.
http://www.roadranger.com/Roadranger...ture/index.htm
Happy reading.
Hope this helps.
Jeff
Old 03-19-2007, 01:23 PM   #6
the_experience03's Avatar
Plan on a couple hundred to have someone set the gears up for you as well. It's no black art, but it takes specialized tools and knowledge to do it. For the price of those components, I can't imagine you would want to mess around with doing it yourself and chewing up a gear set. Heck...if you don't have a press you might not be able to do them yourself at all. I'm still trying to work up the courage to do my Toyota gears and that will only cost me $200 for parts.
Old 03-21-2007, 02:33 AM   #7
Year: 92
Coachwork: ward flat nose
Chassis: international
Engine: dt466 mt643 air ride
The international dealer here in Oklahoma, told me a rebuilt diff would cost me $1400 exchange. And if they did the r&r work I would also be looking at 4 hours labor at $80/hr. Total out the door would be around $1875. That may be cheaper then buying the parts, paying someone to change the gears and your still stuck with removing the old and and installing the new/rebuilt one.
Also, I have a 4:44 ratio that I was thinking is too slow, and am looking for a 3:73 ratio. But then again you may have a v8 or faster turning 360/5.9 engine, which may be perfect with the 4:44 ratio.
kotflb is offline   Reply With Quote
Old 03-22-2007, 02:02 AM   #8
KC10Chief's Avatar
Rated Cap: 60
I've been looking into doing the same thing with my bus. I have a 1993 International with the 7.3 motor and the 5.57 rear end. My bus is a 10 window bus and it will top out at 65 mph. But the RPM's are screaming at that speed. Even at 55 mph, the RPM's are high. I've only had it on the highway once when I drove it home. The rest has been around town. I can tell you, that with 170 HP, it will be a real dog with lower gears. It's already a dog! I would LOOOOOVE to have some 3.73's in my bus, but I don't think it would move. My bus is empty right now and it's already almost 16,000 pounds. I'm thinking that 4.33's would be realistic, but then, you're going to have to give the engine some more power. I've looked into turbo's and what not. It's VERY expensive. I have also called the International dealer here in OKC and it will be roughly $1,500 for the parts and labor. This isn't a job you want to tackle yourself. Even replacing the gears on a small truck is very difficult. Have you seen the size of the diff on a bus?!? Wow. For what it would cost to rebuild the rear end and then juice the motor up enough so you could drive down the road, you could just buy a different bus with a DT466 in it. Now THAT would be sweet! I'm thinking that I may just leave my bus as it is and drive it 55 mph everywhere I go. I won't be in that big of a hurry anyways.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 03-22-2007, 12:06 PM   #9
I'll ask Tim at UTB about the axle he has apart from a TC2000 today. Maybe, just maybe that third member would work for you guys. I have no idea what kind of axles the Bluebirds use, but most I have seen in these parts have very friendly highway ratios.
Old 03-24-2007, 06:33 AM   #10
oakspring's Avatar
Year: 1985
Chassis: International S1800
Engine: 9.0L Diesel
Rated Cap: 54
Howdy norcalgold! I'm a refugee from Humboldt and a graduate from HSU....miss all the green, but love the sunshine here in Colorado. It sounds like we all have similar issues regarding speed. I've got plenty of power in my Skoolie with a 9.0L V8 Diesel, but with a 6.5 rear end the top end is seriously lacking. I really don't like running my bus full out just to drive 55
I'm really wondering what is the better way to go. I talked with a local International rep about this and he suggested that I might want to consider increasing the ratio to 4.11 or 3.90 but that I'd lose some hill climbing power and I might rather consider a compromise with either 4.56 or 5.17 ratios....I'M SO CONFUSED!!
I have a friend that is a heavy equipment mechanic and works for CDOT and I'm going to talk with him this weekend about such options. I'll get back to you'all if I have anything further to illuminate. I will tell you norcalgold climbing out of Humboldt with a bus is an experience ESPECIALLY if you are taking the highway over to Redding, that last leg will really test your brakes and calm. Of course going south by way of the Redwood Narrows and Suspicion Hill you'll swear you're going to leave paint on the side of the trees and rocks
I'll get back to everyone on the rear end ratios....later
Steve
oakspring is offline   Reply With Quote
axle ratio change kotflb Everything Else | General Skoolie Discussions 16 11-01-2017 08:28 PM
1995 25 Passenger??? Intl 3800 RandyBob2 Everything Else | General Skoolie Discussions 1 10-07-2011 07:37 PM
'Big Red' - 96 Intl. Corbeil 6 Window Stuff Skoolie Conversion Projects 3 07-21-2011 11:06 AM
Parts Sale - Cleaning out my bus parts! syke Classifieds | Buy, Sell, Swap 2 07-13-2011 05:43 PM
better gear ratio cheap lapeer20m Conversion General Discussions 21 05-20-2006 09:35 PM
