Old 07-28-2018, 07:20 PM   #41
If you plan on installing tanks...make sure they are DOT approved. Otherwise you might wind up getting nailed for a 2000 mile tow if you get caught.
Old 07-28-2018, 10:08 PM   #42
Originally Posted by Stu & Filo. T View Post
Hey & since we're on the subject & I know it's a simple question but one of the tanks when I picked it up had a copper ground wire on it, Any reason why I can't run it from one tank to the next then clamp it to the frame?
Your tanks are grounded somewhat by your framework. It's got a few points of contact with the tanks in a tight fitting frame. That gives some continuity to ground if the metal is fairly clean.
Doing as you suggest removes any doubt about a ground on the chassis/frame. That is a good thing especially around propane where a stray spark or some static charge might choose to dissipate as you refuel.
You might also drag a small piece of chain to take all stray current to the earth, tires don't do that. Well, maybe airliner tires do etc but not vehicles that I know of. I could see those tires on a fuel transport that delivers to gas stations etc. They are a bomb ready to go off just as our buses can be
if certain procedures aren't followed.
Old 07-30-2018, 06:27 PM   #43
golfersmurf57's Avatar
Buy a static strap to ground the bus get a overly long one hopefully with multiple mounting holes and adjust it periodically. Won't snag on anything and if it breaks off won't wind up in a tire.
golfersmurf57 is offline   Reply With Quote
Old 10-19-2018, 01:27 PM   #44
Tanker Pilot's Avatar
Year: 2005
Chassis: Blue Bird
Engine: 8.3 L Cummins, MD 3060 Trans
Rated Cap: 50
If there was an emoticon for throwing a book in the air and walking away, I’d use it.
Tanker Pilot is offline   Reply With Quote
Where to mount the propane tank lbranin Alternative Fuels | Electric, Propane, Wood & Biofuels 13 06-13-2018 07:32 PM
Threaded rod to mount tanks White99z Conversion General Discussions 6 11-30-2014 03:59 PM
How to mount tanks underneath? Diesel Dan Plumbing, Water and Waste 3 12-14-2009 11:28 AM
what is adequate ventilation for propane tanks adamanderr Conversion General Discussions 4 03-06-2008 07:06 PM
Propane tank mount & waste tanks installed... GoneCamping Conversion General Discussions 0 11-05-2006 10:30 PM
