Old 07-17-2019, 07:18 PM   #21
Chassis: Flat Nose 40 Footer
Rated Cap: 85
Water pressure can vary from location to location. I've tested pressures up to 95 psi at a residence which could potentially burst a thin-wall tank if the opened outlet wasn't large enough.
The other thing for me is I might mount a couple of them (the pvc pipes) vertically with an "air valve" to add compressed air so I can create enough water pressure as to not need a 12v or 120v pump at times. Lots of possibilities.
Dennis Carey
The "NoRushBus"
TheOaksmith.Com
NoRushBus is offline   Reply With Quote
Old 07-17-2019, 08:57 PM   #22
Coachwork: Tomas
Engine: 7.3l
Guess a tanks a tank but I appreciate all the input.The abs idea isa pretty cool idea, I plan on putting the tank or tanks under my bed as it gets f###### cold here. Nothing to complicated easy to get too. Oh to build one of these where it doesn't get cold
Frogpondfoug is offline   Reply With Quote
Old 07-17-2019, 09:46 PM   #23
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
If ever in colder climate I would keep fresh water above the floor to prevent freezing.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 07-25-2019, 10:27 AM   #24
Coachwork: GILLIG
Chassis: G18E102R2
Engine: Cummins ISC 8.3
Rated Cap: 23 sits 33 stand
Good Vendor in Indiana USA
I located a NSF ANSI STD61 certified water tank at classAcustoms.com. 42 gal that fits my location, $99. US shipped to my door in Texas USA. I would assume they would ship to a more northern state. They also have a good price on other tanks. They specialize in catering truck equipment. No bull just customer service.
oleman is offline   Reply With Quote
Old 07-25-2019, 12:21 PM   #25
brokedown's Avatar
I bought a pair of 55 gallon food grade plastic drums for $5 each in St Louis last month. They were previously used to hold apple cider vinegar. Now I've got 110 gallons of water storage hanging from my frame. I spent far more in PVC fittings than in the barrels themselves.
Old 07-25-2019, 02:51 PM   #26
Sojourner used 55gallon poly barrels. Check out his build thread.
I see those (good grade) on CL for $10-$15 regularly.
Old 07-25-2019, 02:56 PM   #27
Hey Josh,
I didn't see your post until after I posted. I didn't cat
storage, tank, water
