07-17-2019, 12:23 PM
Coachwork: Tomas
Engine: 7.3l
Where's cheap water tanks
I've Looking for cheap water tanks in Canada for while now and I must not be looking in the right place.
Here's my best options at the moment . Shipped to my door.
2x26ga is $450
1x63 GA is $520
The prices are too steep for me. Yes I know I live in Canada and I should already know we pay more but errrrrr
If you know of a good deal let me know that I can get in Canada let me know
Thanks
07-17-2019, 12:30 PM
All sizes, low pricing. I bought 3 in different sizes.
https://www.ebay.com/itm/42-Gallon-F...72.m2749.l2649
07-17-2019, 12:33 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
2x26ga is $450
1x63 GA is $520
Thanks
buy a water damaged trailer or motor home for less than the price of some of those tanks, and get tanks, cook stove, refrigerator, furnace, plumbing, toilets, propane valves and tank holders etc, etc, and in the case of a trailer, have a frame with wheels, suspension, wiring and lights ready to put a deck on to haul your whatever to where ever you want, all for the price of a holding tank
07-17-2019, 12:56 PM
Coachwork: Me
Chassis: 2001 IC
got my 50 gallon for 65$ and its food grade. Place in IL if you need the contact info msg me and I will dig it up.
07-17-2019, 01:00 PM
Coachwork: Tomas
Engine: 7.3l
I've been doing that, actually working in my awning tonight I just got from a camper. but for my drinking I'm going new
07-17-2019, 01:40 PM
Chassis: Tc2000
Engine: 5.9 24v
Rated Cap: 27
I got a 40 Gallon tank from a crashed food truck for 15$.
It was a good deal but a bitch to mount.
In hindsight I would pay money for a new one that was easier to mount.
07-17-2019, 02:06 PM
Originally Posted by o1marc
Wow that’s a great price!
Did you use this for black water too?
07-17-2019, 02:08 PM
Compost toilet, no black water tank. I have 2 fresh water and one gray. No reason it can't be used for a black tank.
07-17-2019, 02:18 PM
Coachwork: Me
Chassis: 2001 IC
same here compost only, no black tank on the bus. 100 gal fresh water bout all I want to haul gets pretty heavy.
07-17-2019, 02:21 PM
Coachwork: Tomas
Engine: 7.3l
Those are good deal even after conversion.I'm probably going with them. It's risky as customs is a pain when shipping but way cheaper than what I've been looking at. Knew Asking that question on here be a good idea. Thanks again
07-17-2019, 02:28 PM
Coachwork: Me
Chassis: 2001 IC
Keep in mind you get what you pay for. I have seen many different holding tanks. Some are paper thin and welds were knocked off just looking at them. I have recently bought a ICON holding tank and it is worlds of difference then the cheap ones I bought previously. The way they are welded and formed makes a big difference.
07-17-2019, 03:05 PM
Coachwork: Tomas
Engine: 7.3l
Thats why I'm skeptical about eBay these days. How flimsy are these eBay ones
07-17-2019, 03:17 PM
Engine: 3208 na boat anchor
I bought (2) rectangular 50 gal. Ronco tanks through Northern Tool, largely because the shipping was reasonable.
07-17-2019, 03:41 PM
Coachwork: Tomas
Engine: 7.3l
I'm guessing the icon tanks would be the best ones but Damm pricy
07-17-2019, 04:13 PM
for me I would look at use case.. if momney is tight and your rig is going to be within a half day of a city or other civilization then perhaps the top of the line tanks arent needed.. a leak doesnt become a possible serious issue.. but if you are travelling way out in the desert.. .. long distances from anyone and everyone.. I'd want to make sure my water supply is as safe from leakage as possible...
07-17-2019, 04:40 PM
Chassis: Flat Nose 40 Footer
Rated Cap: 85
So as of now, I'm leaning towards 10" PVC pipe with a 3/8" wall thickness that will mount under the bus. Haven't decided on the length yet, I need to look at placement options.
The price is competitive with the cheapest of other holding methods and you don't have to worry about the "sloshing" factor or filling your tank under pressure. The pressure is a big deal to me because I want to fill my tanks that way.
Here are a couple of links for price examples and dimensions or sizes available. There will be a supplier in your area so no shipping. I want the keep the space under my bed available for storage also.
https://pvcpipesupplies.com/pvc-pipe...e?pipesize=480
https://www.pvcfittingsonline.com/re...18-through-24/
Dennis Carey
The "NoRushBus"
TheOaksmith.Com
07-17-2019, 04:41 PM
I suspect even the good ones are sold on Ebay. Just cause it's ebay doesn't mean it's junk.
07-17-2019, 04:43 PM
If a $50 tanks adequately does the job, what advantage is gained by spending more money for a "better" one?
07-17-2019, 04:56 PM
10" x 10' = 40 gallons
Elaborate on "Pressure filling". I use a gravity feed that you stick the hose in the spout and fill till it comes out the vent, that way no pressure in the tank to bust it.
07-17-2019, 05:51 PM
Rated Cap: 37,400 lbs GVWR
Look for a rotomolder / rotational molder (or moulder for any Canucks!) anywhere close by. Who makes all the tanks used on farms there? If you have a choice, use a rotomolded tank instead of one welded from lots of separate pieces - it's always going to be stronger. Getting the tank is only half the story: you also need all the fittings for inlet/outlet/vent/etc spin-welded into place because polyethylene cannot be glued reliably. A good rotomolder will have a selection of different fittings, but choose the heavy-duty ones that are thicker: they distort and stretch less when you thread something into them. And if you can transport the tanks yourself you'll save a lot of money.
I paid US$2.50 a gallon for my tanks when Ronco made them a few years ago, including spinning in all the fittings exactly where I needed them. That should give you some idea of what to pay, ish.
