Old 01-20-2015, 08:26 PM   #1
which is better
which is better shuttle bus or school bus i will be pulling a trailer.
fnelson71 is offline   Reply With Quote
Old 01-20-2015, 08:31 PM   #2
Which eyes colors see better? it will be mostly dark....
Malkieri is offline   Reply With Quote
Old 01-20-2015, 08:51 PM   #3
i can get a 94 25' bumper to bumper ford f350 with a 7.3 with a/c front and rear with 181000 miles for $3000 or i can get a 95 35' internation 3800 with t444e auto with 165000 both buses have new tires im just wondering which is easier to convert and which would be better over time.
Old 01-20-2015, 09:15 PM   #4
Its really up to you, how much room do you want? there the same motor, not sure what tranny is in there. As to which one is easier to convert, just depends what you want in it. I can't say anything about towing, i haven't towed yet but i will be soon. I don't see any problems, but the 7.3/ t444e are no power houses.
Old 01-20-2015, 09:34 PM   #5
Typically, skoolies are much heavier duty construction while most shuttles are pretty light structurally. Load capacities are generally very much higher for skoolies as well. Either way, find out the GVAW for each then get an actual scale weight. That's really the only way to determine how much load you can safely add. Whether in build out or towing. Good to know the front and rear axle ratings as well.
Old 01-20-2015, 10:38 PM   #6
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Air brakes? Those are nice for towing.
I personally hate shuttle - style buses. But then again, I run a proper, big bus company ;)
The bus will be more solid. The tail will wag the dog less, so to speak. Hard to say if fuel economy will be different--gearing and top speed are factors here.
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 01-21-2015, 05:01 AM   #7
Coachwork: ward
Chassis: international
Engine: dt360a
the longer wheel base will be better for towing and you WILL want the extra room if staying in it for extended times.
Old 01-21-2015, 05:32 PM   #8
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
When I was calling around for insurance the only place that would insure a skoolie was Good Sam AS LONG as it WAS NOT a van chaissie bus
Old 01-21-2015, 05:48 PM   #9
Always make sure the tow vehicle weighs more than what your towing, unless your 18 and know it all...then it's just an adventure
Old 01-21-2015, 08:50 PM   #10
thanks for the info everyone
Old 01-21-2015, 09:07 PM   #11
Bansil, you're killing me Bro. Jack
