Old 11-28-2010, 09:53 PM   #11
edfrank's Avatar
Coachwork: Wayne Lifeguard
Chassis: Navistar International
Engine: 7.3 Power Stroker Diesel
Rated Cap: 24
Re: Which is the best electric heater for less than $50?
Guys,
If you look at the wattage rating of all of the electric heaters that run on house current, they all max out at 1500 watts. That is the limit. They all produce about the same amount of heat it just depends on how well they distribute the heat. The oil filed radiators have oil which stores the heat in their mass, so the heat will be more even over time. One that doesn't have the storage mass will turn on and off and go ht an cold in regular cycles (unless it is producing max heat at all times). So the net amount of heat will be the same, it just will vary more. The small ceramic heaters are the most efficient and small. The oil filled ones have the most even heat and are bigger. The other thing to consider how well the fan in them works. A better fan means the heat will be better distributed over a larger area. look for one with a fan that will broadly distribute the heat.
Ed Frank
edfrank is offline   Reply With Quote
Old 12-03-2010, 06:12 PM   #12
Year: 1978
The oil radiator type heat the area close to them but the warmth doesn't reach very far. The heat also travels upward too so your feet will be cold while your head is warm. The ceramic fan type are cheap to run and circulate the heat nicely.
Lady Chicory is offline   Reply With Quote
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
electric 7 gallon water heater bansil Electrical, Charging and Solar 11 12-08-2011 09:44 PM
Mr. Heater propane heater glock17 Conversion General Discussions 15 10-21-2007 08:59 AM
Electric Water Heater hoser Conversion General Discussions 3 04-26-2006 09:29 PM
Electric Engine Coolant Heater busone Everything Else | General Skoolie Discussions 4 10-17-2005 12:21 AM
