Old 11-18-2010, 09:20 PM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Which is the best electric heater for less than $50?
I'm looking for an inexpensive space heater for the bus. Right now I've got two like this: http://www.homedepot.com/h_d1/N-5yc1vZ1 ... ogId=10053, but I have to run them on the low setting or they cut out. They are really not doing the job.
So which heaters work well? How about the oil-filled heaters? Or the radiant heaters? Or just plain old utility heater with heating elements and a fan?
Here are some of the options I'm considering:
Anyone have experience with any of these types of heaters?
I want to get something next week because we will be spending the night in the bus on Thanksgiving, and will have access to electric.
Thanks!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-19-2010, 10:23 AM   #2
Year: 1983
Chassis: Carpenter
Engine: 8.3
Re: Which is the best electric heater for around $50?
I am with Smitty the oil filled space heater have many benefits, quite, even heat you cant beat them.
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 11-19-2010, 10:26 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Thanks guys, I guess I have my answer! God, I love the internet!
Kid's today don't realize how good they have it. We were in the information dark ages when we were kids.
Gallery:
Conversion Thread:
Old 11-19-2010, 10:54 AM   #4
lornaschinske's Avatar
Rated Cap: 89
We have a Patton Milkhouse type. It's 1500W (two fan speed) and heats well. I have got to dig it out of the shed because we are using Staceys similar unit (lakewood brand) but it doesn't heat as well as the Patton. Looks similar, similar ratings but just doesn't heat as well as the heavy duty Patton we have. When we downsized our storage units, I sold off about three of these. Only kept one. We like this brand. When it tips over (even if not completely) it will shut off. Stacey's heater will not. I believe we bought most, if not all, from Wal-Mart. I know the last one (the one we currently have) is from WalMart.
http://www.amazon.com/s/ref=nb_sb_no...ater+&x=8&y=19
Fulltime since 2006
Old 11-19-2010, 08:09 PM   #5
opus's Avatar
Chassis: All-American R/E
Re: Which is the best electric heater for less than $50?
I have had 2 of them oil radiators going all day. That surely wont cut it for me, not even close. Bummer...I was thinking they might be a good idea too.
Old 11-20-2010, 09:55 AM   #6
opus's Avatar
Thermo-insulated curtains all around. Nothing done to the ceiling though. I couldnt find a way to do the ceiling. I would rather spend more to heat than fuss with the ceiling. In the future, we might put something up there but not sure what yet. I cant afford to lose any more height though.
Old 11-20-2010, 06:28 PM   #7
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
i got two of them oil filled ones going in my rv
Old 11-20-2010, 10:22 PM   #8
Rated Cap: 89
Originally Posted by opus
T... Nothing done to the ceiling though... I cant afford to lose any more height though...
Perhaps you should try what George Myers did to his coach when he needed to have more insulation although I would have added a lot more than he did. He added 1 inch... if going to that much trouble, I would have added at least 4 inches.
http://www.busnut.com/bbs/messages/1...tml?1165275072
Fulltime since 2006
Old 11-23-2010, 11:56 AM   #9
Diesel Dan's Avatar
Engine: DT466/AT545
Seems like we have some different opinions on this subject (imagine that!) . I can see how the large size of the oil-filled heaters would be a drawback, especially in my relatively small bus. I may need to set the heater in a cabinet, so I'd also like to have one with a fan that pushes the heat out rather than just a radiator. I may try one of the utility heaters like Lorna mentioned. I really like the small size of the ceramic heaters I have, but they do not function properly since they cut out when on the "high" setting. Has anyone else experienced that type of problem with a heater?
Gallery:
Conversion Thread:
Old 11-23-2010, 01:40 PM   #10
Year: 1983
Chassis: Carpenter
Engine: 8.3
It could be a faulty hi-limit thermal switch in the heater, I have worked a bunch on brewers and hi end vending systems and I have noticed space heater I have played with off the clock have these switches and they are not as reliable as they can be especially when they get a bit older.
Here is a picture of one check the voltage while the unit is on and watch if it kills the power to the element or if the issue is up stream from the problem
http://t3.gstatic.com/images?q=tbn:ANd9 ... 8GEVDIYyRV
seth
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
electric 7 gallon water heater bansil Electrical, Charging and Solar 11 12-08-2011 09:44 PM
Mr. Heater propane heater glock17 Conversion General Discussions 15 10-21-2007 08:59 AM
Electric Water Heater hoser Conversion General Discussions 3 04-26-2006 09:29 PM
Electric Engine Coolant Heater busone Everything Else | General Skoolie Discussions 4 10-17-2005 12:21 AM
