Old 01-17-2019, 06:45 PM   #1
Sleddgracer's Avatar
Chassis: still looking for my bus
which motor/transmission combo would you pick?
which motor/transmission combo would you prefer?
Bus #02-01 2001 FREIGHTLINER FS65 72 PASSENGER S/A BUS C/W: Cummins ISB 5.9 litre, diesel, 205 hp, A/T, spring susp, A/C, 10000 lb frts, 19000 lb rears, 276 in. WB Hours/Mileage: 367,112 km, 10613 hours
Bus #02-04 1998 INTERNATIONAL 3800 72 PASSENGER S/A BUS C/W: Cummins T444E 7.3 litre, diesel, 190 hp, A/T, spring susp, A/C, rear view camera, 276 in. WB, fire suppression Hours/Mileage: 198,799 km, 10836 hours
Bus #02-06 2001 INTERNATIONAL 3800 72 PASSENGER S/A BUS C/W: DT466E 7.6 litre, diesel, 195 hp, Spicer 7 spd, spring susp, A/C, rear view camera, 10000 lb frt, 19000 lb rears, 276 in. WB, fire suppression Hours/Mileage: 231,269 km, 7922 hours
Old 01-17-2019, 07:59 PM   #2
The 2001 International ALL the way.
Roll Your Own Build Thread
Old 01-18-2019, 06:15 AM   #3
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
I agree! The 2001 Freightliner would be pick #2, but the mileage is a bit on the high side. I would not consider #2.
Dave
Old 01-18-2019, 06:46 AM   #4
definitely the 01 navistar.. both the FS65 and the 98 navustar have pretty high hours.. the T-444E is likely goingto need injectors soon at that number of hours.. and wont have the power you are looking for..
Old 01-18-2019, 08:23 AM   #5
Chassis: International 1753
Engine: 6.9 International
3rd, followed by 1st and then 2nd
Old 01-21-2019, 02:41 PM   #6
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
#3 all the way
I would do the DT466E and the manual transmission all the way. Wet sleeve engine and a manual transmission.
FamilyCircus is offline   Reply With Quote
Old 01-21-2019, 03:09 PM   #7
That one should have an OD for 7th, right?
Old 01-21-2019, 03:17 PM   #8
Chassis: GA39530
Rated Cap: 40
I was looking at doing a cable shift FSO-8406 Fuller 6 speed, but then I thought about mom having to drive it in the hills of Colorado, yah Ill keep the Allison.
Old 01-21-2019, 08:25 PM   #9
Engine: 466DT
There are two spicer 7 spds. Both are syncronized. One is over drive.
Es52-7b, which I have, and an ESO66-7b. O for overdrive.
Es52 gear ratio's
1-10.09
2-5.98
3-3.72
4-2.56
5-1.81
6-1.35
7-1.00
R-8.99
ESO66
1-7.48
2-4.43
3-2.76
4-1.90
5-1.34
6-1.00
7-.74
R-6.66
I have driven many manual transmissions. It's not my favorite, but nothing wrong with it either. It does not like to be shifted in a hurry.
Hvbuzz is offline   Reply With Quote
Old 01-21-2019, 08:50 PM   #10
Engine: 466DT
The last one would be my choice also. It's about the same spec as mine, except electronic. The 195 is low on hp like mine was. Which you won't be able to get easy hp gains like my mech engine. Mine was ok with the orginal 190hp and 4.44 gears and 10r tires. Once I went to 4.10 and 11r tires I needed the extra hp.
