Old 09-26-2019, 05:24 PM   #1
Year: 2005
Engine: 365 International
Rated Cap: 22 handicap accessible
Which rear lights do you have to keep working
Okay, this might be a dumb question, but I'm thinking I might not be the only person who's wondering + I have an idea for the back of my bus that will require I understand this.
So I made a handy little image with the identical lights on each side of a bus's rear having the same number so those who know can inform me easily
My Q :: Which of these lights/reflectors must I keep in working order? All? I assume not the very top ones (#s 1 and 2).
Thank you (and feel free to laugh),
Shannon
Shannon Elhart is offline   Reply With Quote
Old 09-26-2019, 05:42 PM   #2
Year: 2005
I hope this will post the image directly rather than a link
Back of bus image:
Old 09-26-2019, 05:53 PM   #3
3,4,5
6 is a reflector, right?
Old 09-26-2019, 05:58 PM   #4
..and the 3 at the very top centre as well as the 2 on the sides at the back corners.
You'll be needing the clear backup lights as well.
Old 09-26-2019, 06:06 PM   #5
Year: 2005
Yeah, @Danjo, I think 6 is a reflector
I totally overlooked the three at the very top and the two on each side, very top! Thanks, @BlackJohn
So we need to keep:
the three little ones at the very top (that I did not mark)
the two small ones one the top sides (just around the corner ;) )
and
3, 4, and 5
Correct?
(btw, I do not have my bus yet... need to pick it up, so I have nothing to look at - LOL)
Old 09-26-2019, 06:08 PM   #6
1&2 can be used for the lasers.
Old 09-26-2019, 06:10 PM   #7
Year: 2005
'Lasers', @Danjo?! Are you messing with me?!
Are we talking Burning Man?!!?
Old 09-26-2019, 06:14 PM   #8
Photon torpedoes?
Old 09-26-2019, 06:17 PM   #9
Year: 2005
Omg, yes! Photon torpedoes!!! Did Heisenberg have those on their bus?! ;)
Old 09-26-2019, 06:20 PM   #10
So we need to keep:
and
3, 4, and 5
Correct?
Seems you have your rear end covered Shannon, and welcome. No life like it!
Old 09-26-2019, 06:21 PM   #11
Crystal Ship had phosphine gas cannons
Old 09-26-2019, 06:31 PM   #12
1 & 2 need to be removed or disabled as flashers or repurposed as brake and turn signals. Everything else is required IINM. With the exception of the 2 red lights (5)above the rear reflectors. I doubt they are required for anything other than the white light in the bottom of the left one to light the license plate. On mine the upper ambers are turn signals, and the reds will be bright white back up lights.
o1marc is online now   Reply With Quote
Old 09-26-2019, 06:45 PM   #13
Year: 2005
LOL, @BlackJohn, THAT was a great pun!
My rearend is covered... but not quite... I have a unique idea that I'd love some thoughts on.
Watch for a new post, and I'd love your feedback!
Old 09-26-2019, 06:47 PM   #14
Year: 2005
Thanks so much @o1marc - that is really helpful!
Old 09-26-2019, 06:48 PM   #15
Same applies to the upper lights on the front.
Old 09-26-2019, 09:34 PM   #16
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
Check with your DMV to be sure but the top, (#1+2), as well as the corresponding upper flashing lights out front have to be removed completely in my state.
Good luck in your hunt...
Old 09-27-2019, 02:22 AM   #17
Chassis: IH
#1 and #2 may be safely removed. I repurposed mine with new LED lights to duplicate the Stop, Tail, Turn functions from the ones below. Turn signals may be yellow (amber) or red in the U.S., but if using amber, there cannot be a steady light facing rearward. Since my bus, for some reason, had red turn signals on the back, I chose to make all 8 replacement lights on the back red and all of them function as tail lights. I want maximum possible visibility for following drivers. The upper clearance and marker lights will likely switch to LED's at some point, as will the lower, smaller brake and license plate ones.
All the other lighting is federally mandated (for vehicle size and weight, regardless of use and function), do you think bus builders would add any more lights (IE, spend any more money) than they absolutely had to? Even factory built RV's have the same lighting setup (mostly, they are only required to have 1 pair of Stop, Tail, Turn signals in the back).
Old 09-27-2019, 05:02 AM   #18
Here is a link to a post with a link to the actual federal document:
http://www.skoolie.net/forums/f49/ru...tml#post350568
... and here is the link to the document:
https://www.govinfo.gov/app/search/%...fset%22%3A0%7D
Old 09-27-2019, 06:38 AM   #19
I think 4 and 5 are redundant except for maybe the tag light.
You don't have to have 4 tail lights.
Roll Your Own Build Thread
Old 09-27-2019, 12:29 PM   #20
If all 8 are red, what do you use for turn signals?
brake lights, bus lights, rear lights, which lights
