Old 06-14-2010, 04:07 PM   #11
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Who has kept their rear heaters?
Kept mine (only had one) in the B-700, will certainly keep one (maybe both) in the Genesis...I will use the bus in the winter, so they stay. I would (and did) remove them to do the flooring & reinstalled when it was done. (Actually, I reinstalled when the interior was mostly done because I didn't want to work around them.)
Also: they're a quick heat-dump if the engine starts running hot. Probably won't keep it cool, but may let you get someplace better than where you see the gauge creeping up.
Jarlaxle
Old 07-02-2010, 08:46 AM   #12
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
the valve for your bus hearter is in the eng compartment .open the dog house an look down at the rear of the eng and on the left side conner theres a valve,,i belive its a t-valve if it been replace it well look like the one on your house for your hose,,,, hope this helps
last rodeo
keith is offline   Reply With Quote
Help me take my heaters out. jjhomeonewheels Conversion Tutorials and How-to's 7 08-27-2017 09:13 PM
Removing rear heaters / cap lines? buswizard Conversion General Discussions 4 07-17-2010 07:46 AM
heaters?? gbstewart Conversion General Discussions 0 05-19-2010 05:01 PM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
Heaters How can i be safe when using propane powered heaters andybus9 Conversion General Discussions 1 01-12-2004 12:01 PM
