Old 04-04-2011, 07:58 PM   #1
Engine: T444
Rated Cap: 22
Whole new problem this time with the brakes
Right from one problem to the next, by the time I got the high beams on the brakes started acting up. When I apply the brakes they function normally but when I release the pedal it doesn't come all the way back up. It's and International with some kind of power assist hydraulic brakes that I know nothing about. Anyone experience anything like this? Where should I start looking?
Roachhill is offline   Reply With Quote
Old 04-05-2011, 05:57 AM   #2
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Re: Whole new problem this time with the brakes
vacuum hose leaks?
Ob1 is offline   Reply With Quote
Old 04-05-2011, 07:02 PM   #3
Engine: T444
Rated Cap: 22
I didn't know it had vacum hoses. I guess I don't understand this brake system at all. I assumed it must be a hydraulic issue but once they start adding extra parts I got lost.
Old 04-05-2011, 09:42 PM   #4
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
I dont know that it has vacuum powered assist either, but that is the common way to do it. Find a manual on that machine yet?
Old 04-06-2011, 02:10 PM   #5
Engine: T444
Rated Cap: 22
No manuals yet, the dealer offers a CD with all the info but it's awfully pricey. I've kinda blown the budget already, at least for awhile. The master cylinder is huge with 2 seperate reservoirs and an electric motor mounted underneath it. No idea how the thing works, Does it sound familiar to anyone? I am either going to have to start searching blind for a solution or park the bus and wait until I can afford to have a pro check it out. I suppose the first ramdom repair will be bleeding the system if I can find someone to help me with it, then start guessing from there.
Old 04-11-2011, 05:08 PM   #6
Engine: T444
Rated Cap: 22
Well I gave up on trying to fix the brakes and took it to a shop. What a mistake, it cost me $300 to have them tell me it will cost $1200 to fix it. Since I don't have $1200 that was $300 wasted (that I can't afford). They said it needs something called a Hydraulic brake assist head unit. Anyone have any idea where I might be able to find a used one cheap. I think buying a bus was a huge mistake and the best I could do is to try to find a used part to get it working so I can try to sell it off. Anyone need a bus?
Old 04-11-2011, 08:11 PM   #7
Engine: T444
Rated Cap: 22
Yep specifically a Hydro max Hydro boost by Bosch, my internet search got alot more productive once I learned the correct name for the part. To bad I didn't figure out what the part was called during business hrs so I could do some calling around. It seems a rebuilt unit cost $265 without the core charge so a used one should be pretty affordable if I can find one local. I'm supposed to head out of town on Saturday so it will need to be a local part if I want to be up and running on time. I found a tech manual from Bosch online so at least I understand how the thing works. I'm still ticked that I wasted $300 trusting a garage just because I didn't understand the system. $300 just for an estimate and I still think they are just taking a best guess. My guesses are free.
Second time around newbusser Skoolie Conversion Projects 26 03-19-2015 09:49 PM
How to Adust Air Brakes ( Check Brakes ) lapeer20m Conversion Tutorials and How-to's 6 10-04-2013 01:10 PM
RE: BUS WITH AIR BRAKES AND TRAILER WITH ELECTRIC BRAKES? XE1UFO Conversion General Discussions 3 07-21-2010 11:55 AM
Once Upon A Time timbuk Everything Else | General Skoolie Discussions 0 05-06-2010 07:06 PM
Problem with brakes/Starting (hydraulic?) Les Lampman Conversion General Discussions 5 12-16-2006 09:56 PM
