Old 03-19-2007, 01:09 PM   #11
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
One reason is to add a foil-faced layer of insulation with the foil facing the *outside*, just under the external steel bus skin.
We just had our hottest day so far -- 97 degrees outside in southernmost Arizona. The sun altitude was around 57 degrees @ solar noon....and our bus was only 2 degrees warmer than the outside air temp. Not bad for what is essentially a steel tube with no A/C or evaporative cooling.
There are other factors...white paint, east-west bus orientation, and having every door & window open for max air flow. Our two doors are on the north (shaded) side of the bus, so the coolest available air is moving through the bus.
Hope this helps
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 03-24-2007, 10:50 AM   #12
Elliot Naess's Avatar
Engine: 5,9 Cummins
Is there something with a better R-value?
Try researching polyisocy... polyisocyan... oh heck... take a look here:
http://www.daviddarling.info/encyclo...cyanurate.html
Elliot
New to this - Structural, Heating and Insulating Questions Ilexis Heating, Cooling and Appliances 5 10-15-2014 06:01 AM
Insulating question wmkbailey Conversion General Discussions 13 01-22-2014 06:24 PM
DIY Insulating Window Quilts lornaschinske Everything Else | General Skoolie Discussions 8 08-13-2012 08:58 PM
insulating hood? gbstewart Conversion General Discussions 6 09-24-2010 10:07 AM
Insulating for winter Hawkcreek Conversion General Discussions 2 10-01-2006 02:20 PM
