Old 08-07-2019, 10:10 AM   #1
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Chassis: IC FE 9 Window
Rated Cap: 29850
window AC unit over rear door vs mini split
I have seen a few installs where a mini split evaporator is mounted over the rear door and the condensor is mounted out back or right above.
Why not just cut a hole, weld a frame, and then slide in a window unit? Seems simple and easy.
PeteinSF is offline   Reply With Quote
Old 08-07-2019, 10:18 AM   #2
Some have done just that. I have also seen folks mount them in a side window with the ability to remove it for travel.
The mini-split is much more efficient and will run easily on a smaller generators.
The mini-splits are generally much quieter.
Old 08-07-2019, 11:50 AM   #3
I stuck one in a window in the garage to use while building. It works well enough that I will store it in the bus garage and use when needed. Sticks out too far to leave it while driving.
Old 08-07-2019, 06:27 PM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Had a reply all typed out but, my "token" expired. I'm not going to type all that again on a phone.
