Old 09-26-2007, 01:41 PM   #1
swinada's Avatar
Window removal and Buzzers
If I remove the emergency exit windows, what do I do with the wires for the buzzers? Can I just clip them, or will I then have a constant buzzer and will be unable to start the bus?
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 09-26-2007, 01:46 PM   #2
Steve's Avatar
Re: Window removal and Buzzers
The buzzer probably works the other way as in the buzzer will go off if the circuit is open, so in that case you just clip the wires and wire them together. It should be easy to tell which way it is by experimenting.
Old 09-26-2007, 10:18 PM   #3
Engine: 7.3 diesel
I gave my buzzer away to someone who needed it for a charterbus. It was the first thing I removed from the bus after removing the seats.
caulk removal butcher_boy Conversion General Discussions 6 04-09-2019 10:46 PM
Rear cap removal SmokinJ Conversion Tutorials and How-to's 2 08-10-2014 06:35 AM
2001 Amtran window buzzers betmerick Conversion Tutorials and How-to's 0 04-07-2014 09:42 AM
dumb question window removal Desertdueler Conversion General Discussions 6 01-28-2007 08:00 PM
seat removal Jody Conversion General Discussions 3 04-18-2006 07:59 PM
