If I remove the emergency exit windows, what do I do with the wires for the buzzers? Can I just clip them, or will I then have a constant buzzer and will be unable to start the bus?
The buzzer probably works the other way as in the buzzer will go off if the circuit is open, so in that case you just clip the wires and wire them together. It should be easy to tell which way it is by experimenting.
