Re: Window Screens for Bus
I bought running lengths of screen frame and of course screen material, aluminum not nylon, and frame corners for assembly. I made frames that fit tight between the vertical trim around the windows. I just used aluminum colored silicone to hold them in place (no screws) and have never had a problem with them coming out. You would have to cut them out to replace them. I only screened the upper/opening part of the window and not the lower and have had just a little trouble with little critters getting in, (there is a small gap along the lower edge) you let more in through the door most the time. I think it looks better than screening the whole window. I haven't looked at my pics in the gallery to see if the screens are visible but will after this note, take a look and see if you can spot them, they're almost invisible I think. sportyrick
