Old 05-18-2016, 04:46 PM   #21
Year: 1987
Engine: 6.9L Diesel
I sensed a sincere knowledge based tone behind your solid rivet suggestion/insistence. I feel I should reevaluate my decision now. I can probably hustle my wife into holding a bucking bar, would holding a bucking bar demand strength or is this something that could be done by someone with the strength of a 8 year old boy?
If I change my plan according to your suggestion, could I have you confirm the following?
I should use stainless steel (or steel) rivets, either 3/16 or 1/4 inch depending on the existing thickness of the current rivets which are in the bus.
The length of the rivets should be about 1.5x the thickness of the total steel I'm joining.
I should predrill, set the metal, get a lot of clico's to hold the metal over the bus, and then hustle me some help to do it the right way with solid rivets?
Thanks again for taking interest!
Old 05-18-2016, 05:20 PM   #22
Chassis: TC2000 RE
Engine: 8.3l Cummins
Yes, she would be able to do it fine. The bucking portion is simply holding a heavy bar against the rivet so you have a hammering surface. It is physically demanding, after a while. Just stop doing it for the day when you're too tired.
Use 3/16 or 1/4 where necessary. On the bluebird, the rub rails appear to be set with 1/4 rivets, and the 3/16 are in the roof and walls. Use the same or similar spacing they did, and pre-drill and get a ton of clecos. The more clecos you have, the more you can work in advance predrilling holes.
I'd probably go with regular steel rivets since they're a lot cheaper, but you'll need to make sure to paint them. An additional thing you can do is treat each hole with a quick shot of cold galv spray paint, which will help cut down on corrosion significantly.
Clecos are magic and will be useful for tons of things. They are basically removable rivets, and will hold the panels together. Use whatever techniques will work for you to get the panels in place, like that bottle jack jig, or just muscling them into place. Once they are there, you can drill and mount a couple to get going. When you drill your holes, drill in a pattern that spreads the metal out and does not induce ripples or bubbles. You want to drill and then add clecos then drill some more. Don't pre-drill everything unless you're really sure it's dead on.
In some cases, I'll skip drill holes, then add clecos to all those, then go back and drill the holes between. The clecos help hold the metal panels (ribs and sheets) together so the hole I drill is precise.
I think the best way I visualize it is it's sort of like applying a big sticker to a surface, you start in the middle and spread your way out so you don't trap any air under it.
A 4x rivet gun is the size you want if you haven't done this before. Anything smaller will wear you out and take longer, anything larger is too heavy or risks damaging the vehicle.
Using a bucking bar is all about technique, hearing protectors, and some work gloves. It's not that heavy, but it will vibrate the piss out of your hands after a while, for both parties involved.
The trick is to develop the language on both sides of the panel. Here's what I do:
Riveter: (optinally remove cleco first)
Riveter: Insert rivet
Riveter: Immediately position rivet set on rivet head to hold in place. (Riveter keeps pressure on gun and set because of the next step)
Bucker: Place bar against stem of rivet, give one firm push, but not enough to push the rivet out of the hole - indicates "ready"
Riveter: Pulls rivet gun trigger for specified amount of time. This will take practice, but you can tell when to stop by the sound. As soon as the rivet is fully set, the tone changes.
Bucker: when rivet gun stops, watch for next rivet to be pressed through hole.
Riveter: repeat process
This whole exchange happens very quickly once you've got practice at it, and it's why you can pre-drill a ton of holes if you have a giant bucket of clecos to hold everything in place.
It's sort of fun, working as team because you get to read each other's mind and work together to get it done. Occasionally something happens, like a rivet drops out, or it goes sideways, or doesn't fit, or an additional hole is drilled, but that's all fine.
aaronsb is offline   Reply With Quote
Old 05-18-2016, 05:59 PM   #23
Year: 1987
Engine: 6.9L Diesel
Vigorously scribbling notes
You're getting me excited about doing solid rivets now! Between my wife, my neighbors kids who won't leave me alone, and my kitchen staff who owe me favors I think we can make this work.
Do you think a cheap ebay cleco set like this would be fine? I appreciate your explanation of them, I was reluctant to reveal that I had very little idea of what a cleco is. From what you tell me, cleco's sound like exactly what I want to use.
Old 05-18-2016, 06:45 PM   #24
Jolly Roger's Avatar
Engine: Detroit 8.2
The hot rivet thing was supposed to be a joke.
Buy a rivet gun and use closed end solid rivets instead of the hand sqeeze tool pop rivet style. At the time I was working for a company that I had surplus of things to work with and the stainless was an option I had available and chose over steel rivets?
You can find the tools and material and do anything you decide!
Old 05-18-2016, 06:54 PM   #25
Chassis: TC2000 RE
I picked up this rivet gun kit, and it has served me well. It's a step or two up from super cheap ones, but it's not something I'd be using to drive rivets in my painstakingly maintained P-51R with bright gloss aluminum finish.
Robot Check
Cleco kits:
Robot Check
Find which ones work for you and order more of the same size, they come in different sizes, differentiated by colors.
Old 05-18-2016, 08:17 PM   #26
Year: 1987
Engine: 6.9L Diesel
Thank you for the tips! I think I sent you PM with my info, feel free to contact me anytime. I'll hopefully begin this project by June.
Old 06-04-2016, 10:39 PM   #27
Year: 1987
Engine: 6.9L Diesel
So as recommended I went ahead and purchased the boulderfly 4x rivet gun, the suggested cleco set, another 100 3/16 cleco's, about 600 solid 3/16 x 5/8 solid steel rivets, and 100 1/4 x 3/4 rivets just in case. I'm on the verge of buying precut galvannealed 18 gauge steel but I just wanted to confirm run one question that pushed me to delay my metal order.
Am I okay using one long sheet to skin over 3 or 4 windows at a time? Or will that make buckling more likely? My original plan was to skin over 2 windows at a time, but then after reading a few threads I flip flopped and decided to ask everyone's two cents. Thanks in advance!
Old 06-05-2016, 05:57 AM   #28
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
i covered 4 windows, about 10 feet with one sheet of 18 ga. no problems. i used screws so it would match what i have. i used a polyurethane based caulk between the two. i paid about 150 bucks for 2 sheets blasted and sheared to size. good luck
my build pics
Old 05-24-2021, 11:04 AM   #29
Solid rivets.
I know this is an old thread so I am not sure anyone will see this.....stupid question, I bought the "pro" air rivet gun from Harbor Freight. It says it can handle 1/4" rivets. I bought 1/4" by 1/2" solid round head rivets and the shaft does not come close to fitting the rivet gun. What am I missing here?
KoehlerFarms is offline   Reply With Quote
Old 05-24-2021, 11:49 AM   #30
Solid rivets? I think you want blind rivets.
Old 05-24-2021, 12:07 PM   #31
ewo1's Avatar
the rivet gun should come with extra tips that will accommodate different size rivets.
For rivets I used "Magnalock" rivets.
you can get more info on this thread.
https://www.skoolie.net/forums/f13/b...ets-34197.html
Old 05-24-2021, 01:05 PM   #32
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Can you post a photo of the rivets? Like musigenesis alluded to...you may have solid rivets for bucking...which is a different process altogether. I have the Chief riveter from Harbor Freight and it does, indeed, work with 1/4-inch blind rivets and "pop" rivets. Is this what you have?
Name:	Screen Shot 2021-05-24 at 11.04.39 AM.png
Old 05-24-2021, 06:44 PM   #33
Coachwork: 44' Newell Coach
Engine: 8v92T Detroit
Rated Cap: 2 adults and two pigeons
I bought an Astro rivet gun from Amazon and it could not pull the 1/4" stainless steel blind rivets I was using. I then bought a Sunex gun from Amazon and it did the trick The Sunex gun was $300 and almost twice the size. After about 1600 rivets, it still works like new with another 1000 or so to go by the time I am done
--Simon
Bus'n it is offline   Reply With Quote
Old 05-25-2021, 01:21 PM   #34
Yes, same gun. The rivets that are on my bus are solid rivets, not blind rivets. Looks like going with the blind may be the way to go I guess. Thank you.
