I'm going to reskin the bus and I will be deleting some windows but I want to leave the exit windows on the side and two more in each side up front so I have been looking around and I can't find something that fits exactly, basically it will require cutting one rib to have a big window up front and find another exit window to replace.
The openings I have are 26x29" and if I remove one rib in the front 54x29" and I have found windows that are exit windows but 26x30 ( required opening) so it means that I might have to cut half inch each site to fit it and the 54x29 will require to cut one rib and reinforce to fit.
is this recommended/standar way of installing new windows in a bus ?
are frameless windows bad ? there is some on sale that are close to the size that are fair priced....
