Old 02-05-2016, 08:03 PM   #1
Year: 1987
Engine: 6.9L Diesel
Windows: single pane vs dual pane vs school bus standard
Hi Everyone,
I'm ashamed to say I've had my bus for longer than I'd like to admit, and I am getting ready to make some moves soon. Which makes me want to ask a few questions regarding windows.
After a lot of flip flopping, I am starting to muster up the guts to take out the windows and put in RV windows. I just found a handful of windows on craigslist which I am contemplating getting, at $20 a piece. I've been told the sizes range from 1'x1' to 2.5' x 5' all of which are single pane.
Will I be regretting buying these single pane and installing them? I was thinking I would get all of the 2.5 x 5' windows, and that I would put some sort of insulating sheet over them. Also, if I stack these on top of each other and install them as makeshift dual pane will that work?
I am assuming single pane RV windows will still insulate better than the school bus standard windows? Thanks for your help everyone, I will start posting pictures of the bus soon.
Old 02-05-2016, 08:34 PM   #2
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Yes, rv windows, even single pane are a big upgrade from the stock windows. Youre getting a god price on them, but make sure the will fit in the orientation you need. RV windows do have a top and bottom.
If you buy multiple windows from the same seller on ebay, you can save a lot on shipping. This is what I did and I went with double pane because I prioritized livability in cold and hot climates. If you're going to the trouble of replacing the windows, id spend the extra and get the double pane. Just my .02
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 02-05-2016, 10:02 PM   #3
Year: 1987
Engine: 6.9L Diesel
Thank you! I really appreciate your input. I will sit on this thought for a minute.
Old 02-05-2016, 11:36 PM   #4
Yes, RV windows are a big upgrade.
windows insulation
