Old 08-16-2009, 01:48 AM   #1
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Winter and a Bus... (and a glance at my hippy bus)
now that is most definatly a old skool bus i like it! hope to see more of it here or in bc! even older than mine welcome,timbuk
Old 08-16-2009, 06:36 AM   #2
TygerCub's Avatar
Engine: Detroit
Welcome to the group!
Looks like you have a nice bus there that's already been outfitted with all the comforts of home. If I understand the situation correctly, you're not quite ready to do a complete tear-out and rebuild, right? But want to know how to make it comfortable enough to live in for the winter?
One of the easiest and least expensive short-term things for you can do is Ice Czar's #3 suggestion: "zoned heating". This could be as simple as hanging thick blankets between the living and sleeping areas and moving a portable heater into the space with you. Or you could get a little more creative and construct a wall between the "rooms" complete with a door... but, that involves construction which you may not be ready to tackle yet.
The second easiest and least expensive thing for you to do is insulate with a heat reflective material. Since you have shag carpet already glued to the walls, you've already created a small thermal break between the metal and the living space. Unfortunately, shag carpet isn't a great insulator, so you may consider temporarily layering this type of reflective insulation over the carpet to bounce the heat back into the area where you stay the most.
Large rolls of this foil-faced bubble wrap is some of the least expensive insulation that is the easiest to work with and provides a decent amount of insulation for its thickness. Most hardware stores carry this stuff in 4' x 25' to 150' rolls. In the spring or summer, this stuff is great to reflect the hot sun out back out of your windows... and is easy enough to roll up and store out of the way if it's no longer needed. When you are ready to do a complete tear-out and rework, you can recycle this stuff and use it in the walls.
And there's nothing to say you can't combine the two efforts. Since you have a large sleeping area, you may wish to portion off a smaller area that will be easier for your body to heat and double insulate that smaller space. This will allow you to sleep a little bit better... and getting a good rest is very important to how you'll perceive the general comfort of the day. In the summer, open that space up again to allow body heat to dissipate.
One of the most expensive, but in my humble opinion the best overall solution, is to install a wood stove. Several folks have wood stoves that were created specifically for boats. These tiny units are great for busses because they were designed for small spaces that are in constant motion. Information on these stoves may be found here: http://www.marinestove.com/installation_views.htm
Above all, be creative. Something as simple as a fish tank can act as mass thermal storage. In the winter, just make sure to insulate at least four of the six sides (bottom, sides and rear of the tank) to help maintain a healthy temperature for the fish. The potting soil in house plants can also act as thermal storage. Again, make sure you insulate the body of the pot to help it maintain temperature.
Have fun, and good luck!
P.S. - Don't be afraid to post photos of the interior of the bus. We're all curious skoolies here.
Old 08-16-2009, 09:28 AM   #3
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Welcome Nicky! Diggin your "old skoolie"... You have a nice old bus & we all here at skoolie love all buses... Turn on your flash on your camera & post bunches of photos of the ins & outs of your baby!
Jonathan
ezbme is offline   Reply With Quote
Old 08-19-2009, 09:52 AM   #4
Year: 93
Chassis: ?
http://www.marinestove.com/installation_views.htm[/url]
I like this interior....I would not have thought to look at boat interiors for ideas
Thanks
swhite832 is offline   Reply With Quote
Old 08-19-2009, 11:47 AM   #5
TygerCub's Avatar
Engine: Detroit
Because of the tiny size and severe weather sailboats often encounter, they are great examples to look at for space-saving ideas.
Originally Posted by Nicky
So will that alum bubble insulation stuff work well enuff> or is there somthing 1 step up i could use?
The bubble insulation is just one of many layers of insulation to use on the bus. Do a search in this forum for insulation and you'll find a great deal of information already discussed.
Good luck! Hope you have loads of fun!
EDIT
Just did a quick search myself and thought this link was the most informative of them all:
http://www.skoolie.net/forum/viewtop...lit=insulation
Hope it helps!
Old 09-13-2009, 08:06 AM   #6
Year: 1963
Engine: 640 Detroit allison
Great looking Bus.. looks suspiciously like Boo-Boo..with a roof deck! I love it!
hmcastle55 is offline   Reply With Quote
History show about an old hippy bus frank-id Everything Else | General Skoolie Discussions 9 05-15-2017 04:58 PM
Hippy bus in SantaFe PRyberg Classifieds | Buy, Sell, Swap 0 11-12-2009 06:09 AM
Pictures of Hippy Schoolbuses...Rainbow Gathering odyssess Classifieds | Buy, Sell, Swap 1 05-10-2008 01:40 PM
winter bus! captainkf Everything Else | General Skoolie Discussions 17 02-18-2008 06:12 PM
A real hippy bus frank-id Everything Else | General Skoolie Discussions 6 09-13-2006 02:42 AM
