Old 05-23-2016, 10:29 PM   #1
Engine: CAT 3208 V8
Winter-proof plumbing?
Is it possible to install plumbing that can withstand below-freezing temperatures? What are the logistics this if it is possible?
EschatonExpress is offline   Reply With Quote
Old 05-23-2016, 10:59 PM   #2
Chassis: Genesis
PEX is pretty much your only option if you want it to survive ice in the line and even that is questionable. Put an air compressor blow out on the line and get rid of the water inside the pipes for long term storage is what is normally done.
Timelord is offline   Reply With Quote
Old 05-24-2016, 06:10 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
If you're talking about living in it in the winter, you will have to keep all water both fresh and waste inside of a compartment that is heated is some way.
Old 05-24-2016, 06:22 AM   #4
I've thought of this issue, keep my fresh water in tank under my queen mattress, will a spray foam layer help with a black/grey tank I know they sell heating pads for starts at grow shops you can get them in almost any size I bought one that was 24x48. The rest was trying to run my lines internally.
dodgeoboy is offline   Reply With Quote
Old 05-24-2016, 09:51 AM   #5
Robin97396's Avatar
It might be cheaper to buy those electrical floor heating systems which come in a variety of sizes, and they can be cut to fit. It's the internet alternative to the hydronic floor heating systems. Just a thought. Haven't compared prices.
Old 05-24-2016, 04:24 PM   #6
Engine: CAT 3208 V8
Good solutions. I've got a fresh tank under the bed already, so that's good. I would assume that the black tank would be kept above reasonable freezing temperatures by the self-generated heat of the waste.
Another question: how do you all feel about drinking fresh water from a PEX pipe system?
Old 05-24-2016, 05:11 PM   #7
Chassis: TC2000 RE
Engine: 8.3l Cummins
I think millions of households don't mind. Pex is used all the time for residential and commercial plumbing.
aaronsb is offline   Reply With Quote
Old 05-24-2016, 06:03 PM   #8
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Electrically heated hoses and holding tank blanket are available just for this purpose.
