Old 10-03-2014, 02:35 PM   #1
turf's Avatar
winterizing pipes
its getting cold here and i dont want to damage any new plumbing before it gets used.....so yesterday i drained the plumbing.
and then i started thinking....
it sure would be nice to have an some air.... to blow out the plumbing lines and water tank.
hey wait....i got on board air....
so, can you hook up a valve or 2 and make a "clear the line" plumbing dump valve? is it wise to do so?
does anyone use air for winterizing their rig? or just the rv juice?
Turfmobile Build Thread
Old 10-03-2014, 03:02 PM   #2
Re: winterizing pipes
dry is best, so...I have used pink antifreeze in the past...wont ever again, pain in the arse to clean out pipes for next year and it's $$$$$
so I plan to just drain and blow out lines and drains, if worried about a certain area, heat tape or a 40 or 60 wt bulb (old incadesant type) will keep a small area above freezing
Old 10-04-2014, 07:35 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Yes, you can use onboard air. Use an air regulator to cut the air pressure down, you don't need all that much. Don't forget to drain water heater, toilet valve and pipe above the shower valves.
Old 10-04-2014, 10:06 AM   #4
roach711's Avatar
Rated Cap: 19
I set up my plumbing so that the two ends (water tank and water heater) are the low points and in theory at least, should be able to drain my pipes just by pulling the plugs on each end. Last year when i drained my system I pulled both drain plugs then, just to be sure, sucked out the water heater end with my shop vac (I've got no air compressor) and was surprised how much water was still in there. Relying on gravity to drain the plumbing doesn't work so well.
Be sure to empty your drain traps and the little strainer thingy on the water pump. Once the tank is empty I run the water pump for a few seconds to clear it, too.
The Roach Motel
Winterizing Chfsfn2 Conversion General Discussions 11 10-29-2023 05:31 PM
Winterizing/Mold/Moisture protection for our bus opus Conversion General Discussions 2 02-15-2013 07:49 PM
Where do I find these hoses/pipes? spirit_of_76 Conversion General Discussions 0 05-21-2010 08:13 PM
winterizing.... C00LR Conversion General Discussions 4 11-20-2009 12:09 PM
Gray and black vent pipes oldog12 Plumbing, Water and Waste 17 10-14-2006 12:08 AM
