Old 09-11-2007, 08:39 PM   #1
Train-train's Avatar
wiper parks streight up and down in my view
I just have been going over things in my bus and noticed that the driver's side wiper will not park to the side. I have thought about taking off the arm and remounting it to the side. I wonder if it will then cycle across the window correctly? Is there a right way to fix this problem?
Train-train is offline   Reply With Quote
Old 09-11-2007, 08:45 PM   #2
lapeer20m's Avatar
Re: wiper parks streight up and down in my view
i have an international thomas body bus and have the same problem. I actually turned the wiper arm so it would park to the side, and the automatic gizmo put the wiper right back smack dab in the middle of my view. It's odd, because the passenger side wiper sits off the the edge like it oughtta.
i've found that if i turn the wiper switch so it's in between hi/low the wiper motor looses current and will stop. if you time it right you can stop the wiper blade all the way to the edge. I've gotten really good at making it stop out of my way, but i'd be way happier if i found the correct fix.
Old 09-12-2007, 10:59 AM   #3
sportyrick's Avatar
Chassis: F33695
I assume you have electric wipers and not air. Electric wiper motors have a switch built in to them that powers the motor until it gets to it's parking area and then breakes the circuit (this happens after you turn off the power to it, it's hot all the time on one side so be careful). If your switch is dirty or broke (copper arms with contacts on the end of them) then it will stop where ever you turn the power off. Take it apart and look inside for the contacts and see what condition they are in, adjust accordingly. sportyrick
Texas Parks & Wildlife lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 1 11-20-2014 09:15 PM
Can't view gallery crazycal Forum Admin | Account Help | Suggestion Box 9 09-19-2012 08:08 PM
Goverenment Parks Passes... GoneCamping Conversion General Discussions 1 06-12-2008 10:31 PM
U.S. NATIONAL PARKS TO BE OFF LIMITS TO AMERICANS lapeer20m Everything Else | General Skoolie Discussions 1 05-05-2008 12:27 PM
Is there a maximum bus length in State or National Parks? greyguzziart Everything Else | General Skoolie Discussions 1 12-21-2006 06:56 PM
