Old 07-21-2011, 03:39 PM   #1
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Wiper question
89 thomas
wiper switch has 4 wires
I am assuming that 1 is hot, one is ground, 2 for slow and high speeds.
Do I have to have the ground hooked to the switch? I have a 3 pole DPDT switch.
I took the ground off the original and wipers still work.
SO, do I have to have the ground hooked up?
by the way, the ground wires on the switches are colored white on one and black on the other
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 07-22-2011, 08:53 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Wiper question
Unless the switch works by grounding whatever it is controlling,which is rare, there would be no reason have a ground wire to the switch.
Old 07-22-2011, 09:29 AM   #3
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Wiper question
I unhooked what I think is the ground wire, having 3 wires to the switch left on, they still worked, so I dont know, guess I will get out the meter. Its funny though, one is white on one switch and the other is black on the other.....
Old 07-22-2011, 10:39 AM   #4
Stuff's Avatar
Re: Wiper question
aslong as you can figure out what each wire does and you hook em up accordingly, should be fine. lol if you're paranoid put a fuse before the switch
Old 07-22-2011, 08:02 PM   #5
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Wiper question
#1 wire from fuse panel
#2 wire from harness-it is hot when turned on
#3 wire to slow speed wipers *note same harness
#4 wire to fast speed wipers * note same harness
wipers will work with #2 unhooked
wipers will not work if #1 unhooked
could this be an illuminated switch that has a blown bulb maybe?
windshield wiper tech bansil Conversion Tutorials and How-to's 2 07-03-2013 10:18 AM
windshield wiper pivots bapos Mechanical and Drivetrains 2 10-26-2012 12:05 PM
Wiper arm for 83 Ward bus bapos Classifieds | Buy, Sell, Swap 17 09-29-2012 09:04 PM
Im in need of a wiper arm for my bus bapos Mechanical and Drivetrains 4 08-10-2011 07:14 PM
wiper motors timbuk Conversion General Discussions 9 10-18-2008 08:39 PM
