Originally Posted by Rameses
I don't remember who it was, but somebody took pieces of metal and painted them with regular paint, paint with the ceramic beads, paint with sawdust added, etc. Measured temperature on the back side in direct sunlight and concluded that the sawdust was equally as effective as the beads when added to elastomeric, if I recall correctly.
It was me and here's the post:
http://www.skoolie.net/forums/f13/in...ease-9291.html The test starts on page 4.
From my experience the HyTech beads (or sawdust, whatever) provide almost zero real insulation. White paint
does reflect sunlight, which provides a cooler surface. No 100 micron thick product can provide any noticeable insulation.. It's been proven time and time again. The results people see and feel are due to the sun's light being reflected away instead of being absorbed, which is an important property, but it's not insulation.
Someone should do a similar test to mine, but in the winter and on the inside of their bus..
EDIT: Actually, I forgot that somebody already
did do some tests in the winter!
http://www.cchrc.org/docs/Insulating_Paint_Final.pdf.
