Old 08-12-2019, 03:25 PM   #21
CrazyDave's Avatar
Originally Posted by Miles O Roads View Post
The problem I see is space around required. You will proballly need 2' or more all the way around it. So one of these will quickly take up alot real estate.
A Mobile Home approved stove, with or without a water reservoir will have tighter clearences than a conventional one. If you're looking for full functionality in the confined space of a bus conversion, J.A. Roby will likely be your best option. Their stoves are designed for tight spaces, and can be set up for outside combustion air.
https://www.discountstoves.net/wood-cook-stoves-s/37.htm?searching=Y&sort=5&cat=37&show=300&page=1&f-Mobile%20Home%20Approved=439
CrazyDave is offline   Reply With Quote
Old 11-08-2021, 12:05 AM   #22
BusDreamerRick's Avatar
hello I am wondering what cook stove this is? We are looking to put one in our skoolie
BusDreamerRick is offline   Reply With Quote
