Old 02-29-2012, 10:18 AM   #11
Re: Wooden Roof Deck Problems?
The supports under the trex looks like 2x2's..
Old 02-29-2012, 11:51 AM   #12
Year: 1994
Chassis: Amtran
Engine: Injternational diesel
Rated Cap: 64
Thanks for the pictures. I really want to build a full length deck on my bus, I'm trying to figure out a way to get some kind of insulation between the roof and the deck. Has anybody stuffed some sort of insulation in there?
mosagra is offline   Reply With Quote
Old 02-29-2012, 12:40 PM   #13
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
where did u fine them mounts?? metal brackets
keith is offline   Reply With Quote
Old 02-29-2012, 05:56 PM   #14
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Nope, 4x.4. The trex is 2x6. The galvanized metal pipe is 1".
They are called Kee Klamps, made in the UK. Kinda pricey. Found at McMaster-Carr. At their site search on "structural framing fittings".
These are the McMaster-Carr part numbers for the fittings I used.
4936T91 Iron Slip-On Structural Framing System Rect Flange W/Closed End
4936T71 Iron Slip-On Structural Framing System Oval Flange
4936T64 Iron Slip-On Structural Framing System Adj 180 Deg Rect Flange
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 02-29-2012, 07:49 PM   #15
syke's Avatar
Chassis: All American RE
Thanks for posting the pictures Sean.
Do you have the 4x4 attached to the bus roof in the center? If so what did you end up doing there? Thanks
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 02-29-2012, 08:01 PM   #16
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Yes, trex was through-bolted to the roof, down the centerline. The 4x4 supports attached to that using angle brackets.
Old 03-09-2012, 04:31 AM   #17
Engine: DTA360
Rated Cap: 16
Very cool ideas on the deck... I've worked with trex on customer's homes... It's a little on the heavy side but stands up to weather...
dirtygoat is offline   Reply With Quote
Old 03-09-2012, 10:17 AM   #18
syke's Avatar
Thanks for posting up the pictures Sean.
After looking at your pictures I'm going with the bolt through centerline setup like you did. Thanks again.
Not to hijack this thread but.... did you ever do any camping near Lake Mary? I live in Prescott Valley and plan to make a few shake down runs up the mountain and was thinking I saw a ton of dispersed camping down Lake Mary road. Any suggestions?
Ryan
Old 03-09-2012, 11:48 AM   #19
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Yes, follow signs for Ashurst Lake. Before you get to the developed campground there is a free dispersed camping area. I parked the bus at (35.032603,-111.438599, plug that into Google Maps for the loc) for a while. Nice spot.
Old 03-09-2012, 11:52 AM   #20
syke's Avatar
Got it! Thanks.
Ryan
Roof deck badasp118 Conversion General Discussions 15 04-13-2013 04:13 PM
Roof deck chev49 Conversion General Discussions 1 04-03-2013 10:27 AM
roof deck railing greenmachine18 Conversion General Discussions 4 03-31-2010 04:12 PM
Roof Deck - New Owner Great White Buffalo Conversion General Discussions 13 11-18-2006 03:05 PM
roof deck azredneck Conversion General Discussions 2 06-02-2006 05:37 PM
