Old 06-27-2018, 05:17 PM   #1
Rovobay's Avatar
Rated Cap: 35
Would this be good ceiling material?
https://www.lowes.com/pd/Parkland-Pl...-Panel/3436816
I ran across this in lowes yesterday. rigid yet flexible enough to match the bend of the roof. I literally just picked up some white veneer panels from and RV store before I got to lowes. I could use those panels for the walls I guess.
so what would a thermal block solution be to reduce condensation?
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 06-27-2018, 05:27 PM   #2
Year: 1994
Engine: DT408 6.7L L6
From what I've read some people use thin foam, or thin plywood. I'll probably use will seal which is a roll of thin foam used under window sills.
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 06-27-2018, 05:33 PM   #3
Rovobay's Avatar
Rated Cap: 35
forgot to mention they are 4x8 panels for $20 each and are roughly 1/16th inch thick.
Old 06-28-2018, 11:46 AM   #4
If that's what I think it is, I wouldn't use it. You'll end up with a really wavy ceiling with no water resistance at all from the back side. Also, my personal opinion is that it looks like what they use for the walls in really unappealing gas station bathrooms. It's just ugly. YMMV.
Old 06-28-2018, 02:49 PM   #5
thrifty1's Avatar
Engine: DTA360
Have you thought about using this? https://m.lowes.com/pd/RevolutionPly...4-x-8/50121135
This is what I plan on and it has good reviews and mediocre structural integrity.
thrifty1 is offline   Reply With Quote
Old 06-28-2018, 03:14 PM   #6
Traveling
Did you check the link, it's obviously not what you think. It is plastic and 100% waterproof. I agree the thickness will not aide in a smooth ceiling.
Old 06-28-2018, 05:13 PM   #7
Rovobay's Avatar
Rated Cap: 35
Yeah, I didn't think about the finish being wavy....
