Old 02-22-2007, 11:05 PM   #11
oldog12's Avatar
Don't forget an air-water separator
oldog12 is offline   Reply With Quote
Old 02-23-2007, 12:30 AM   #12
the_experience03's Avatar
Sorry to hijack a thread here, but....would the bus' onboard air dryer be sufficient? I'm not Boyd Coddington and don't require an exceptional paint job, but I would like to do something about my BAD rolled on job that was done just to make things legal. Also...what do most guns require you regulat the pressure at. Anything below 90 and I don't think it would be an issue as my compressor would cut in before then. It might take a while for the compressor to catch back up after a long panel coat, but I don't mind waiting.
Old 02-23-2007, 08:26 AM   #13
oldog12's Avatar
Frankly, I'm not sure if its technically required to have an air-water separator after the on-board air dryer or no, but I feel its cheap insurance to make sure water has all the opportunity it needs to avoid mixing with your paint and not giving you the best chance in getting the kind of paint job you're expecting, or desiring
Old 02-24-2007, 09:01 PM   #14
GoneCamping's Avatar
I didn't use one, everything came out just fine! Get a HVLP spray gun (High Volumn Low Pressure) that way you don't have to worry about the small unit keeping up. Get a regulator to adjust air pressure with... The low pressure system also limits overspray which equates to less wasted paint...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 02-25-2007, 09:25 AM   #15
eggman's Avatar
I'll second the HVLP sprayer, thats what I used and it went well. Also, I didnt use an air-water separator. Paint went on just fine, no problems.
Oldog, you are correct. In the fine state of Illinois your skoolie can not be painted the color of any shade of yellow, nor can the top lights or the flasher on the swingout stopsign be operational.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Sloppy Yellow DanMan80 Skoolie Conversion Projects 83 04-14-2015 07:59 AM
Yellow bus illegal where? rlohrey Conversion Tutorials and How-to's 38 01-24-2015 10:35 AM
the big yellow beer can jolly_rogger Skoolie Conversion Projects 18 09-11-2011 06:37 PM
Yet another reason to not have a yellow bus baadpuppy School Bus News 1 08-24-2009 10:30 PM
How much school bus yellow can I keep? Branden Conversion General Discussions 2 06-03-2005 06:26 PM
