Old 03-01-2017, 02:04 PM   #11
Asetechrail's Avatar
Coachwork: Amtran Genesis
Originally Posted by slaughridge85 View Post
Just bid on the Webasto, nice find and thanks for the link. It's only a couple hrs away from me... $75 bucks seems reasonable to me...
Says "Sold" did you buy it?
Asetechrail is offline   Reply With Quote
Old 03-01-2017, 03:10 PM   #12
Engine: Detroit Diesel 6-71
Rated Cap: 52 pax
All this talk of heating got me thinking... You could put all that under the floor, and I like the idea of doing so, but I'm too tall for my bus already plus it could be hard to service. I do want to find a way to use my tankless WH to heat the back of the bus near the bed. I took out the original rear heater. I'm thinking I could re-plumb it so the hot water recirculator uses the "rad" and fans from the original heater. I could probably even use the original cockpit controls for it too.
Maybe this would be a more simple way of using hot fresh water to heat the bus, just be sure to super clean or replace the heat exchanger (radiator part) so there are no chemicals in it of course.... But you guys get the idea right?
-Chevy
Chevydude01 is offline   Reply With Quote
Old 03-01-2017, 03:52 PM   #13
Rated Cap: Your mom +1
nope, I had it till the last minutes and got busy at work and somebody else swooped in and got it for 95 bucks...
Old 03-02-2017, 04:01 PM   #14
Originally Posted by somewhereinusa View Post
I see, I will get a pump then, any out there that is powerfull enough and runs in 12v , or is better to go with 120v ?
Many buses have a circulation pump for the rear heaters, perhaps someone here might have one, I might have one if I can find it. If you go 120V you will need an inverter to run it while driving.
If you find one or point me to a link of the one you are refering too, I will appreciatte.
pepepito is offline   Reply With Quote
Old 03-02-2017, 04:27 PM   #15
I know Grundfos has a 12v line of circ pumps available in Africa. Not sure if they're imported in the US though. CS0512HM is the model number. The link is a list of authorized distributors. Can't go wrong with Grundfos.
Environmental Distributors *| Grundfos
Old 03-02-2017, 05:37 PM   #16
Ebay doesn't show much, maybe are called something else.
I guess I could use an electric water pump, or it has to be for coolant ?
Any heat rating I should be worried ?
Old 03-02-2017, 05:44 PM   #17
How about one of these off a school bus, circulates water for the heaters. Look up places that sell school bus parts
84chevyguyid is offline   Reply With Quote
Old 03-02-2017, 05:45 PM   #18
I guess I could use something like this :
Auxiliary coolant electric pump
Old 03-02-2017, 05:58 PM   #19
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Those are the units I used price has come down a lot.
Old 03-02-2017, 06:10 PM   #20
Any GPM minimum ?
