Old 03-13-2017, 10:18 AM   #21
Skunky Bus,
Noticed you live in Omaha. I do too. Go Big Red! I'm very knew to the skoolie community and am wanting to buy a bus to start converting. Would love to buy ya a coffee sometime and pick your brain if you're up to it. You can PM me at my email which is just my username @outlook.com. correspondence there would be fine too if you don't want to meet. Just wondering about Nebraska's particular licensing and insurance hurdles I may be crossing and maybe a few other things.
Thank you!
DrillSGTBuddha is offline   Reply With Quote
Old 03-13-2017, 11:08 AM   #22
Rated Cap: 65 pax
Originally Posted by DrillSGTBuddha View Post
Skunky Bus,
Thank you!
I just left Omaha last Saturday Was there for 3 weeks. Met a fellow skoolie there, Lee. I hope you guys hook up!
Sandi
WanderWoman is offline   Reply With Quote
Old 03-13-2017, 11:17 AM   #23
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
Originally Posted by Scooternj View Post
As well as in the engine bay for us REs, and behind any propane appliances.
good call in engine bay! I'm gonna grab an extra for back there.
side note scooter did you read my thread on the tensioner? if not I could use advice.
The road is crazy.
Be safe
Arvik is offline   Reply With Quote
Old 10-07-2018, 12:03 AM   #24
Originally Posted by Njsurf73 View Post
So I belong to a FB group where the owners of this bus belong. They built safely. The passengers were all belted in to Chevy Tahoe seats that were mounted to legs and bolted through the floor. That was my plan for my build and am confident now.
Out of curiosity...do you know if the bolts were directly into the sheet metal floor or were they bolted through the sheet metal floor and through additional steel supports below? Thank you.
Shorty22 is offline   Reply With Quote
Old 10-07-2018, 06:28 AM   #25
You can bolt seat belts through the sheet metal floor with grade 8 bolts and use seat belt washers on the bottom . These washers are heavier and large diameter. Use the correct size for your bolts and the largest bolts your seat frames will handle without modification.
Seat belt washers are sold under that name.
Christopher
Old 10-07-2018, 07:26 AM   #26
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
^^^what he said lol
Christopher
Old 10-07-2018, 08:33 AM   #27
2kool4skool's Avatar
Smoke detectors were mentioned.. On our last glampout the diesel air heater was having issues and wasn't running clean, the CO detector sounded off nicely. I turned off the heater and fired up a Buddy unit that had been sitting for quite a while, the dust on the element had to burn off, that set off the smoke detector!
Good system check, all passed.
Don, Mary and Spooky the cat.
Old 10-06-2019, 01:15 AM   #28
Yeah a lot of folks go for aesthetics vs practicality.
I'll have a full wall behind the "cab".
How are you building your wall behind the “cab”? I feel this is the safest route to go. Are your seats mounted to the bus framework or the metal floor? My passenger seats (behind drive not next to) would have 2 rear facing car seats with a LATCH system.
Amguerrero is offline   Reply With Quote
Old 10-06-2019, 11:24 AM   #29
Coachwork: Tomas
Engine: 7.3l
Tornado could pick my bus up and nothing will move, could winch it out of ditch using my woodstove mount lol.
Frogpondfoug is offline   Reply With Quote
