Old 06-20-2015, 12:27 PM   #21
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I went specifically for a Navistar power plant (T444E in my case) because of the extra costs CAT tacks on, because their parts are proprietary. Cummins parts you can get anywhere, and Navistar parts depend a lot on the plant, but can also be had just about anywhere.
Captain Obvious on deviantArt
Old 06-20-2015, 12:45 PM   #22
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Originally Posted by cosimo View Post
Ok, I found a 3208 vs 8.3 discussion here on this site...I will go and read it.
http://www.skoolie.net/forums/f33/8-...26-a-7716.html
There is no discussion. Stick with the 8.3 Cummins. The only person that will argue for a 3208 over the 8.3 is someone that has one in their bus. Given the choice between the 2, I'm sure even they would choose the 8.3.
I'm hungry!
You Gotta Let Me Fly
Old 06-20-2015, 07:00 PM   #23
Originally Posted by nat_ster View Post
As has been mentioned already, when new, a front engine dog nose bus with a 5.9 cummins and a AT545 trans cost over $40,000 less than the HDT rear engine flat nose bus with a Cummins 8.3 and MD3060.
So $2000 for a old TC 2000 with the basic engine and trans, would make the big bus with the best of everything cost $6000 and up.
I would have no issue paying up to $10,000 for a nearly perfect bus with the best of everything.
Are you made of money?
If not you best skip the Cat engines and the Detroit's.
Cost wise the Cummins and the DT engines rule the fleet.
Ha! No, I am not made of money. That would be nice.
cosimo is offline   Reply With Quote
Old 06-20-2015, 10:36 PM   #24
Alan N's Avatar
Year: 1975
Chassis: Gillig
The 3208 is a fine engine.
But I will trade you my 3208 for your 8.3.
Alan N is offline   Reply With Quote
