Old 06-02-2015, 10:54 PM   #1
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
6.11 ratio rear end Spicer N-190 from International DT360
I just replaced my rear differential, so I'm selling my old one. It's a 6.11 ratio Spicer N-190 from my 1993 International DT360. This is the gears inside the whole "hog's head" assembly. It's pretty simple to change; remove the axles (8 bolts each), move the drive shaft out of the way, remove four bolts on the end and twelve around the edge. Pop the old one out, new one in, and reverse. Voila! Much simpler than changing just the gears, which I've heard is a pain in the butt.
The gears are in excellent shape and there were no large metal shavings in the bottom, just the regular bits of iron dust on the magnetic plug.
I changed mine to be able to go faster, but if you need one for whatever reason with this ratio I'm selling it for $450. I'm located in Statesville, NC, about 45 minutes north of Charlotte. Shipping would be expensive, but I can get a quote if you need.
onenationundergoat is offline   Reply With Quote
