Old 01-11-2014, 11:27 PM   #11
kenny76's Avatar
Re: 89 bluebird
I am interested to know if you ever sold the bus and where you are now.
Not all those who wander are lost.
kenny76 is offline   Reply With Quote
Old 01-14-2014, 04:58 PM   #12
jak
Re: 89 bluebird
Im in lexington ky and fired off a couple of emails
thanks and have a great week
JAK
jak is offline   Reply With Quote
Old 02-26-2014, 08:24 PM   #13
jak
Re: 89 bluebird
so Ive had a few folks scare off of my bus because of the oil burning....... I think it used 2 gallons of oil across the US which is allot....
I dont want any bad carma over being dishonest for money.... so Im clear with folks who talk with me about it....
I am an ASE certified master mechanic with 32 years in the business.... Im an auto tech not a diesel and truck tech which dosent mean much as far as diagnosing or fixing the bus goes but the shops I work for dont have the space for me to bring it in and look at it.... I havent had time to tear into it and really figure it out... and I havent really wanted to... it does not have excessive blowbye and I did check the play in the bearings in the turbo and it seems fine.... if you let it idle for a long time and take off it blows pretty good oil smoke for a little bit and clears up and dosent seem to smoke excessively when running... ...maybe the oil rings are warn or stuck...it idles smoothe and starts well even cold...which leads me to believe the compression is reasonable... I can get engine rebuild kits with pistons for $500 all day long on ebay....I may just pull the head and pan and do an inframe on it... would take me about 20 hours but at that point I may not want to let it go... I think it would be a good bus for someone who will use it as living space and move it from here to there but maybe not a travel bus unless the oil consumption is straitened out... its been reliable for me Ive put 10,000 miles on it .. maybe more...I trusted it enough to haul all of my stuff across country... and it did a great job..
Im not willing to sell it for less then $3000 ... Ill keep it and fix it up but I thought if someone else needed it more then me that I could use a little dough
I hope that helps anyone thinking about buying it
take care
JAK
Old 04-13-2014, 07:35 PM   #14
Chassis: 40ft
Engine: 6cyl international t-d
Re: 89 bluebird
do you still have it? care to talk about a possible deal?
think it would make the trip up to michigan?
rjwojton is offline   Reply With Quote
Old 04-14-2014, 08:14 PM   #15
jak
Re: 89 bluebird
yes I still have the bus and I've recently moved into a new house I'm going to store the bus on friends farm until I figure out what to do with itI would like to sell it but I don't want to give it away so I'm happy to talk and be flexible on price
take care
jak
