Old 10-21-2017, 12:43 PM   #1
98 B700 Thomas
purchased this bus to kill time, get exercise. I did all that and got some Arthritis as well. Time to sell my bus and get home to my wife in Costa Rica. This was my 1st caperenty project since 1989. I see better quality jobs on here for sure. Everything is solid and i think a good trim job will make it look quality.
$6600.00
Hunting bus.camping bus.(NO CDL REQUIRES) Material hauling bus.SHORT persons Bus. A bus for those that need to sit.I built this bus while sitting in my roll around office chair.. The bus has a 8 ft long counter in front on passenger side. Great for Computer or Shooting out the windows. Drivers side has 8ft long Sofa/Bench in Red Naugahyde..a 4 FT Long counter for kitchen. Shelf below. .Side door at kitchen make loading groceries a breeze.. Huge bed across the back is a great sleeper. Plenty of storage underneath. New 4000 Watt generator. 1.7 cubic ft ge chest freezer with Inkbird Digital Thermal Control converts it into a refrigerator o back to a freezer. AC Unit over driver is 5000 btu. I have the exterior cover for the AC Unit that is not shown. 32" Toshiba Tv wall mounted
Material hauler: Are you building something?You could slide two huge I beams in under the bed in from back door to the front or haul 24ft long material and hang the rest out side the back door. No grey or black water tanks.30 Gallon water tank with a 1/2HP Transfer pump. .Using a Transfer pump you can draw water from a well or stream 15 ft below ground level or just use the pump to fill a stock tank etc. Bus has outside faucet.
5.9 Cummins 12 Valve Diesel engine. NO COMPUTER!! Allison MT 645 Trannny. Neither leak or dip.New batteries. Starts. Runs and drives good..Air brakes.
Titled as CLASS A Motorhome. No CDL required. BFG 11R-22.5 Radial tires with excellent tread.Chrome/Stainless wheels.
Extra paint: 1.5 gallons Smokey Grey paint (Rustoleum.) About 1.5 Gallons Green Sherwin Williams that you can convert to Blue.
Too much to list will tell you in person.. Will text more photos.
I prefer that you call. 816-804-2862
Old 10-21-2017, 03:56 PM   #2
Do you have pictures?
Mythriftypenny is offline   Reply With Quote
Old 10-22-2017, 10:04 AM   #3
More in a bit.
