Old 07-16-2018, 06:31 PM   #1
98 international 3800 diesel Dt466e for sale or trade
Custom motor home bus diesel dt466e turbo ran great but need a and primer pump or a pick up in tank
Has
Gray tank
Black tank
Toilet
Shower
Sink
Water self contain tank with pump
30 amp shore connection
Dulle big rig rear and front new tires
TV and 12v TV
Radio
Microwave
2 way fridge 120 did not hook up gas to fridge but can if u want 2 u can also put a inverter under couch so u can run fidgeting going down road powermate inverter
All gas lines done in copper and 15% silver solder
Gas stove and gas furnaces
Also has drivable heat and air conditioning
Also has shore line ac and heat
Sleeps 4 or bunk bed turns in to couch
Storage under bed
And under couch
Last time we used it to go to chimney rock 2 months ago ran perfect
Went to crank 2 weeks ago and no fuel getting to hand pump due to bad I thank there about 25.00 had a diesel mechanic look at it and he said it eather the primer pump or the pick up in tank and there. Is a acsses under sink to get to it
This thing is built like a tank has welded steel floor and wood .asking 15000 If I get fixed before I sell it it will go up
Located in Honea path sc
You can not buy these like this it custom
Will sell it or trade show contact info
Only has 223000 on this million mile motor
And is a automatic trans has air brakes but dont need cdl due to it a rv and it also cheap on I insurance threw good sam club
Only has little more to be finished.
00y0y_3CGknsMngCA_600x450.jpg   01717_as0z23Bmwtk_600x450.jpg   01515_1hZlkuA90tF_600x450.jpg   00n0n_flG3HLb6oyO_600x450.jpg   00x0x_l48AcfyISSG_600x450.jpg
00n0n_3mhqgTr0Izv_600x450.jpg   00n0n_iPx70zrLRyu_600x450.jpg   00L0L_6LbzeCCpd7h_600x450.jpg
Lowell864 is offline   Reply With Quote
Old 07-16-2018, 06:38 PM   #2
Did not see anything in the add that states what you are asking or where the bus is located?
Brlux is offline   Reply With Quote
Old 07-16-2018, 08:01 PM   #3
It's in there, you missed it?
"This thing is built like a tank has welded steel floor and wood .asking 15000 If I get fixed before I sell it it will go up"
No contact info makes it hard to get ahold of the seller.
Old 07-16-2018, 09:10 PM   #4
My email address is lowellfinley864@gmail.com
Old 07-17-2018, 12:36 PM   #5
Thanks, was not there before but has now been added.
3800, bus, dt466e, international 3800, skoolie for sale
