Old 08-23-2018, 01:52 PM   #1
Here to learn's Avatar
99 International 3800 w/ 135k miles
Reimagining Home is listing our first bus conversion for sale! A few of our posts on instagram @reimahininghome lists more details about the bus but if you have any questions, please contact us at reimagininghome2018 at gmail dot com or call Clint at 2672501081.
Here to learn is offline   Reply With Quote
Old 08-23-2018, 02:00 PM   #2
Price
To avoid any confusion, in its current state, I am listing it for $35,000. There are a few things I would like to finish on the bus to make it more complete like trim, flooring, one wall has to be finished, etc., but if I do end up finishing the remaining work, I will be raising the price. There are many pictures on my instagram but if you need any more or would like to facetime to get a better idea of the bus, let me know. Thanks for your time. Clint.
Old 08-23-2018, 05:37 PM   #3
Hi Clint,
There are a few things a potential buyer may want to know....
Engine?
Transmission?
Rear gears?
Running condition?
Level of finish inside?
Systems/equipment?
Tire age & condition?
Location?
Thanks.
S.
Old 08-23-2018, 06:09 PM   #4
1999 international 3800 w/ dt466 & at545. Rear gears, Imy not sure buto I can check tomorrow, I have the original build sheet in the bus. Runs and drives great. I raised the roof two feet, replaced the whole rear steel, removed the front door added a floor and a passanger seat, fabricated a new front door that lowers with a winch and the stairs fold out of the door. The inside is what is not finished. The floor needs a finished surface, the front drivers and passanger area is not in a finished state including the front roof area and the transition, the passanger side wall is not finished. The bus could use trimmed out, it would really change the whole look and the skylights need trimmed out. Systems include 750 watts of solar, samlex 1000 watt inverter, ts mppt 45 charge controller, 24 volt 420 ah batt bank in 8 six volt batteries. The water system has 84 gallons on fresh water storage and a 3gpm 12v pump. Front tires are new, rear tires passed pa state inspection last month. It is in pennsburg, pa. Anything else, let me know. Photos areally on instagram, @reimagininghome . ,
Engine?
Transmission?
Rear gears?
Running condition?
Systems/equipment?
Location?
Thanks.
S.[/QUOTE]
Old 08-23-2018, 07:37 PM   #5
Thank you Clint for the prompt reply.
I have an acquaintance here that is looking. I will pass the info on.
Old 08-23-2018, 10:21 PM   #6
Thanks! Give me a call or email if you have any questions.
