Old 01-21-2016, 09:18 AM   #1
Coachwork: IC
Chassis: CE300
Rated Cap: 32
A REALLY Awesome Carpenter in CA
This bus has it all. The tires look nearly new, the engine is reman...
Someone snatch this up PLEASE!
https://www.govdeals.com/index.cfm?f...15&acctid=7557
Old 01-21-2016, 10:28 AM   #2
Apparently some luggage bays, too! Any idea what "Buyer will be required to sign CARB restriction documentation" means?
Old 01-21-2016, 11:17 AM   #3
I saw that one, I really like it. Only thing I was unsure of is the engine, any idea what model Detroit Diesel motor it has?
bschook5 is offline   Reply With Quote
Old 01-21-2016, 03:23 PM   #4
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
I believe the 6v92... but they say v8, so that doesn't match up. I've seen clips of the Carpenter Coach RE with a 6v92 in them at least. Pretty cool bus.
sammy is offline   Reply With Quote
Old 01-21-2016, 03:29 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
I'll wager "CARB restriction documentation" means papers that say "I understand this vehicle does not meet CARB requirements and cannot be operated in California; I'll remove it from the state immediately" etc etc. I had to sign something like that when I bought a couple old diesel-powered towable air compressors in California a few years ago.
Old 01-21-2016, 04:58 PM   #6
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
According to CARB, If the vehicals doesn't meet the new Regs for commercial vehicals you are restricted to 1000 miles or less a year OR Convert it to an RV get retitled then you are exempt from those standards.
Old 01-21-2016, 06:33 PM   #7
Coachwork: IC
Chassis: CE300
Rated Cap: 32
It just means it isn't passing CA's more than stringent sniffer tests. Not surprising being its a Detroit. Perfectly fine for the other 49 of us!
Old 01-21-2016, 10:17 PM   #8
Yeah pretty sure its a 6V92 or maybe 6v71 by comparing to pictures online.
Old 01-22-2016, 12:39 AM   #9
crazycal's Avatar
You forgot to add the part about killing your first born, burning your house down and grinding rock salt into every piece of land you own.
It might also have a VIN block with the DMV. If you live in CA, I would pass on this one. I would hate to do a conversion then have a ton of trouble at the DMV.
I'm hungry!
You Gotta Let Me Fly
Old 01-22-2016, 05:57 AM   #10
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Someone buy this bus and bring it to FL. Folks would be fighting over who got to pay 12k for it.
